Cheapest way to obtain a 408??
Old 03-21-2006, 02:18 PM
leftme4dead's Avatar
Default Cheapest way to obtain a 408??
I was wondering what the best and perferrably cheapest way to obtain a 408. Would you suggest buying a short block new and then building, or what. Opinions and suggestions please. Also, are 408's forged? Or do you have to have them forged?
Old 03-21-2006, 02:45 PM
ROCNDAV's Avatar
cheapest : Stealing it I'm kidding of course!
Check out Speedinc: http://www.ls1speed.com/enginepackages.cfm
Their Aluminum 402 is even cheaper, and no core required!
Old 03-21-2006, 02:57 PM
Z'mnypit's Avatar
The word "Cheap" and 408 dont really play nice together. There are two 6.0L iron blocks assembled minus the top ends for sale in the sale section. $350. Thats a start, then all you need, its a crank, rods, pistons, machine work, rings, bearings, arp bolts, timing setup, heads, cam, & so on. I guess the cheapest way would be buy the stuff then build it yourself. But then again you may come out about the same.
Old 03-21-2006, 03:37 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Nor does 408 and good gas mileage from what I hear!
Old 05-10-2006, 04:37 AM
MASS seller approved
smok'nZ's Avatar
Default wow
hes wright i paid 350 for iron block,2000 forged rotating assem,still looking for heads and cam and maching
Old 05-10-2006, 05:19 AM
TAQuickness's Avatar
I only saved about $0.50 building my 383 myself. HPE has some great deals on shortblocks ---->
Old 05-10-2006, 06:01 AM
PREDATOR-Z's Avatar
have to budget ~$7000 for complete budget longblock
Shortblock $3700
Heads PP $1500
Cam/ install kit (pump, T-chain, p-rods) $1000
Misc $500
extras: $300
Old 05-10-2006, 06:45 AM
kossuth's Avatar
To me that means one of two things. Eithor A the engine builder at HPE is working for beans (unlikely) LOL or B the is one hell of a markup on parts.
Old 05-10-2006, 07:11 AM
DEVIATE's Avatar
Honestly you can buy one already built just about as cheap as you building one from the ground up. Texas Speed, Speed inc, just to name a couple off the top of my head have some very good deals. Plus you dont have to mess with it. Not near as much down time involved. The reason they are cheaper is because the speed shops have accounts with all of the aftermarket dealers on parts and they get a better discount than joe public does. Therefor they can turn around and make it a little bit cheaper for the consumer. If I was to venture a guess they probably are only making their profit off of there labor involved and very little in part markup. Hope this helps your descision.
Old 05-10-2006, 07:19 AM
smok'nZ's Avatar
mine os costing less than 3500 with bad a$$ heads an cam
Old 05-10-2006, 07:59 AM
99whitews6's Avatar
Shortblock $3700
Heads PP $1500
Misc $500
extras: $300
Man, I wish mine only cost that much! The only things I kept from the stock engine were the pan, pickup tube, coils, and valve covers!
Old 05-10-2006, 11:28 AM
xaon's Avatar
I reused most of my gaskets (only replaced the oil pan gasket), and re-used the pushrods and timing chain from my cammed setup.
I bought a new shortblock, cam, oil pump, lifters, AFR 225 heads, GM MLS headgaskets, ARP headstuds and spent approximately $8000 including tax on some items and additional machining on the heads.
