Patriot Performance LS6 heads 59cc HELP
Old 07-07-2006, 08:07 PM
c5_ls1_6spd's Avatar
Default Patriot Performance LS6 heads 59cc HELP
will these 59cc heads & 2.02/1.57 valves work with my MS3 114LSA cam?
I'll be using stock GM head gaskets.
Old 07-07-2006, 09:07 PM
Ksett's Avatar
No way if they are the 243 casting LS6 heads and not the LS6 style heads, without fly cutting of course.
Old 07-07-2006, 09:14 PM
Quik's Avatar
what?
Old 07-07-2006, 09:20 PM
Jake the SSnake's Avatar
If they are milled to 59cc,NO.If the chambers are welded and machined to 59cc they should work since they wouldn't have lost any p to v clearance from the stock castings.
Old 07-07-2006, 09:30 PM
Ksett's Avatar
Originally Posted by Quik
what?
What can I clarify?
Old 07-07-2006, 10:01 PM
Ls6 heads are #243 castings, patriot "ls6 style" heads start out as #035 bare gm lq9 castings.
From patriots website
LS6 Style Chamber Only Heads:
035 OEM castings
Welded Chambers
Heat treated & machined
CNC Chambers only
Milled to OEM deck height
Bronzes Guides installed
Hardened seats installed
Chamber choices:59,64,68,72
No core required
Old 07-08-2006, 12:20 AM
PREDATOR-Z's Avatar
Need to flycut because of valve size.
If you put 2.00/1.55 valves in there then it will fit if heads unmilled.
Old 07-08-2006, 12:22 AM
jz06man's Avatar
They will fit ..... I have a similar cam with the same heads... No issues here...
Old 07-08-2006, 12:41 AM
PREDATOR-Z's Avatar
VHP 062 same as MS3??
Similar don't mean squat anyways. Duration and valve events is what determine if a cam will fit certain heads.
EXPL: 64 cc 5.3L, unmilled with stock gasket (2.04 int/1.57ext)
232/234 112 will not fit but 232/234 113+0 will
