6.0 vs LS1 heads
Old 07-12-2006, 12:09 AM
BumbyHoodTA's Avatar
Default 6.0 vs LS1 heads
Do the 6.0 heads flow more then the stock ls1 heads, And what is the combustion cambers between the two, I can get some 6.0 heads for 200 brand new, would it be worth it to have them milled and put on over the stock heads? Thanks
Old 07-12-2006, 08:43 AM
radkon's Avatar
If you are talking the LS2 6.0 heads (243 casting), yes they flow better and have a smaller chamber than the 241 LS1 heads.
More info here:
https://ls1tech.com/forums/generation-iii-internal-engine/539925-243-casting-heads.html
Old 07-12-2006, 10:05 AM
Sorry i am talking about the 6.0 truck heads
Old 07-12-2006, 11:53 AM
Gunnar@Patriot's Avatar
The 6.0 truck heads will flow better than a 241 head. Keep in mind that the 6.0 truck heads have a larger 72cc combustion chamber. So if you are looking at a set to replace your 241 castings, you will have to have them milled to get back to your stock compression of 10-1.
Old 07-12-2006, 04:31 PM
How much would i have to mill them to get me to stock?
Old 07-13-2006, 10:01 AM
Approx. .030".
Old 07-13-2006, 11:15 AM
ibanez7's Avatar
how will the engine run if you dont mill the 6liter heads? and stay with the 9.4:1 compresssion that it will create.
also is it worth swapping ls1 heads for the 6 liter head on a bolt-on ls1, is the hp gain worth it!
Old 07-13-2006, 11:44 AM
Biggs's Avatar
It depends on the cam. Head flow is the most important, compression loss will hurt if your cam is too big. The right cam will keep your cranking compression up and will not hurt so much if any. Id mill the 6.0 heads, it is not like it is hard to do or expensive just watch valve to piston clearance especially if the cam is very big.
Old 07-13-2006, 08:25 PM
With it being milled to 30. will i have to get different pushrods
Old 07-14-2006, 03:29 PM
to the top
