WORLD Warhawk LS1X Heads
Old 07-30-2006, 09:12 PM
LSWon00's Avatar
Default WORLD Warhawk LS1X Heads
Is anyone running these new World Warhawk Heads, or has anyone seen any results from them? I've been considering new heads and I haven't heard much about them.
Old 07-30-2006, 09:54 PM
Ferocity02's Avatar
They aren't shipping yet. World still has a few weeks before production begins. I imagine we will be seeing flow numbers in the weeks to come.
Old 07-31-2006, 07:44 AM
LSWon00's Avatar
Cool thanks
Old 07-31-2006, 09:10 AM
LS1Tech Co-Founder
Nine Ball's Avatar
There are a couple threads from World in the LS2/LS7 forum, use the search feature.
Old 07-31-2006, 09:21 AM
LSWon00's Avatar
Hmm seeing that the heads are for a LS1 and not a LS2/LS7 and I DID search in the LS1/LS6 forum where the topic clearly applies with the "search feature." Good day!
Old 07-31-2006, 09:43 AM
SVT THIS's Avatar
Wow, a little brave to be copping an attitude with the owner of the site.
Old 07-31-2006, 01:27 PM
Cobraeater's Avatar
Arrow
NineBall is right. The information on the Warhawk LS1X is in the LS2/LS7 section. Check out the first post here for your answers.
https://ls1tech.com/forums/generation-iv-internal-engine/548277-warhawk-arrival-see-yourself.html
The heads aren't even going to be produced yet for a few more weeks, and World is testing out the LS1X heads in the pic on that thread. No flow numbers or dyno tests yet.
Do a search in all the forums if you don't want to miss anything and don't assume the topic is only in one section.
Old 07-31-2006, 01:40 PM
LSWon00's Avatar
Sorry but when what I'm looking for is specific to the the LS1 and LS1 only according to my sources, I would only look in the LS1 specific section. And yeah it may have come off a little brash but no disrespect to anyone. I was just stating that I wasn't in the wrong. So IMO I was looking and searching in the correct section, since the product was engine specific. Bottom line is the heads are not for purchase yet (even though they're in GMHTP) and conduct broader searches. Now Vacate this post in peace.
Old 07-31-2006, 01:53 PM
Cobraeater's Avatar
Your logic is correct, but Warhawk posted in the ls2/ls7 section because of their new blocks and LS7X heads.
Sure it would make more sense to post the info on the LS1X heads in the ls1/ls6 section, but I guess MerlinPro wanted to keep all the info together.
Old 07-31-2006, 02:01 PM
MrDude_1's Avatar
no, they arnt for the LS1 and the LS1 only...... they fit the entire range of genIII and genIV engines... including (but not limited to) the LS1, LS2, LS4, LS6... and if you wanted to downgrade, they even bolt on a LS7... they fit on a C5R block, and on all of the resleved blocks.
now since most of us that move forward arnt stuck on the old, tiny bore block, we read and search the entire board, and know about everything going on in the GM V8 world... instead of only what someone deems "only LS1"...
id recommend expanding your search horizons to include the entire spectrum of genIII+ engines, before you miss out on the newer things, and end up making a poor choice based on lack of knowledge.
(also, id lose the attitude)
Old 07-31-2006, 05:00 PM
LSWon00's Avatar
Someone lock this up please.
Quick Reply: WORLD Warhawk LS1X Heads
