double springs worth it?
Old 01-14-2007, 06:47 PM
99kamarokid's Avatar
Default double springs worth it?
im thinking of getting the 228 r which has a lift of 561 and one package has springs rated up .600 lift but for another hundred dollars i can get the double roller springs rated up to .660.. is it worth the money?
Old 01-14-2007, 06:57 PM
Grimes's Avatar
i like the idea of extra insurance, but i'm sure a spring similar to 918s will do fine.
Old 01-14-2007, 07:32 PM
the other springs are the comp 918 and the others are prc
staringback05's Avatar
i dont know anyone who has a cam and single springs....its just something you do....i have a AFR dual springs on mine....
Old 01-14-2007, 09:47 PM
N4cer's Avatar
With that low lift, run the 918's. You'd be hurting performance by running dual springs on that cam.
Old 01-14-2007, 09:48 PM
GT Griller's Avatar
Yea 918's will do just fine
Old 01-14-2007, 10:27 PM
byler900f's Avatar
921's are a great spring but really hurt your wallet. 918's do the job well and will save you some serious jack. I have even seem some guys run 918's with up to .605 lift and not have any problems.
Old 01-14-2007, 10:34 PM
1BAD02WS6's Avatar
i run 918s on my cam with .591 lift...doing great after 20k miles but when i upgrade cams soon i will put in double springs
Old 01-15-2007, 12:20 AM
mvvette97's Avatar
I run patriot golds with a 571/573 cam.
Old 01-15-2007, 07:35 AM
slow trap's Avatar
the 918s should last a very long time with a cam with soft ramps like that cam.any reason you are going with that cam over one just like it but with xer lobes which will have .588 lift ?
Old 01-15-2007, 07:42 AM
bjamick's Avatar
Ya when you go over a .600 lift thats when you need the dual springs. IMHO
Old 01-15-2007, 01:36 PM
what kind of cam has the xer lobes? and what are the gains from that over the 228r
