ls1 valves work in ls6 head?
Old 03-19-2007, 03:07 PM
dubrado's Avatar
Default ls1 valves work in ls6 head?
Also does the ls1 use the same gaskets as the ls6?
thanks, I woulda done a search, but it doesn't work, i just get errors
thanks again
Old 03-19-2007, 03:25 PM
marv's Avatar
Gaskets should be the same.
Valves I'm not sure of...I think the LS6 heads had slightly larger valves.
I'd try a search again...worked for me a couple minutes ago.
Old 03-19-2007, 04:16 PM
oange ss's Avatar
yes,yes
Old 03-19-2007, 07:13 PM
67Firebird455's Avatar
I'm with orange ss, yes, and yes. Valves are the same size. Although I heard ls6's are sodium filled (lighter).
Old 03-19-2007, 09:11 PM
oange ss's Avatar
only on the exhuaust, they were also 6mm longer to make up for the smaller base circle cam, however that can be remedied with longer push rods or milling the head..good luck
Old 03-19-2007, 09:14 PM
02silvaZ's Avatar
just step up to 7.450 pushrods with the '02 z06 cam, valves are same size on both, so yes they will work
Old 03-19-2007, 09:55 PM
oange ss's Avatar
6mm = .023 ..need 7.425 pushrods
Old 03-20-2007, 08:18 AM
dubrado's Avatar
awesome...thanks
