Got a BIG PROBLEM
Old 07-05-2007, 01:28 PM
kevins2000LS1's Avatar
Default Got a BIG PROBLEM
I was driving my 2000 Z28 today. And when i tried to start it, i had to make a few atempts then it fired and run good. Got a little further down the road and i noticed a strange noise and my oil pressure gauge was doing some funny stuff. So i pulled into a parking lot, and it kinda sounds like a sreching/sqealing kinda noise alomst like a main bearing. Has anyone experienced this problem or anything like it ???
Old 07-05-2007, 01:32 PM
styoung's Avatar
cant say ive had that problem before but what excatly was the oil press gauge doing?
ProjecT 9's Avatar
was the idle dipping when the oil pressure was bouncing around? could be as simple as a pulley going out on you or your altenator. have you taken it back to the house and checked it out? if so where's the squeak coming from?
Jon
Old 07-05-2007, 02:10 PM
Yeah i got it back to the house. It nothing like a alternator. Its deff. internal. The oil gauge was just going up and down, never got to low. Its just a undescribable sound
Old 07-05-2007, 02:13 PM
brad8266's Avatar
Sounds like its time for a forged motor.
Old 07-05-2007, 03:39 PM
2000TransAmWS6's Avatar
kevin, if you need any help taking it apart, you have my number, i'd like to help!
Old 07-05-2007, 04:19 PM
John i think Justin Wells is looking at buy the Z from me. I gave him a great price
Old 07-05-2007, 04:24 PM
the_merv's Avatar
Sounds like a Bearing..does it Knock as well?
If not could be a Cam Bearing.
Old 07-05-2007, 11:26 PM
slow trap's Avatar
if the oil pressure has dropped it is probably a main bearing. usually instead of fluctuating it just drops pressure and makes an audible knock. hopefully in your case it is something else.
Old 07-06-2007, 08:42 AM
GuitsBoy's Avatar
If the oil was fluctuating while the rpm was pretty stable, then it is likely a bearing...
Old 07-06-2007, 09:15 AM
Yeah i was thinking that it was a bearing. I have a few guys looking buying the car from me now. I dont really have the time or cash to repair it. But im not going to give it away, if i cant sale it i will then just build another motor.
Old 07-06-2007, 11:23 AM
SmallTires's Avatar
Had this same problem on a buddies Z06, he drove it after a new motor was in for about 15 miles then the oil pressure guage started bouncing all over the place and a loud lifter clacking could be heard. Turns out on of the oil passages was getting blocked. Wiped out a main bearing.
Old 07-06-2007, 11:24 PM
If i decide to keep the car what do you guys recommend to do? Just put new bearing in and some rod bolts ??? Ill probably change some stuff up while im in there also.
Old 07-07-2007, 01:04 AM
ThaBirdMan's Avatar
Rip it apart and see
