wont start after cam + lifter swap
Old 07-28-2007, 05:27 PM
juiSSed1172's Avatar
Default wont start after cam + lifter swap
i just finished a cam & lifter swap that took way too long (car hasn't been started in like 4 months)
I cranked it with the coil packs disconnected to prime the oil pump.
I connected them, cranked it again and it back fired once.
Now it will crank and do nothing.
Security light is not on. I have fuel pressure at rail. Help.
Old 07-28-2007, 05:41 PM
SLP4CamaroSS's Avatar
double check all the connections then check it again you might of missed somethign
Old 07-28-2007, 05:51 PM
ive been checkined and checking... where is the cam sensor connection? I heard that one is easy to miss.
also, what grounds on the back of the pass head?
Old 07-28-2007, 05:52 PM
mine where on the driver side the grounds
Old 07-28-2007, 05:56 PM
i have the grounds on the drivers side all hooked up, but there is a bolt on the pass side as well for grounds.. it's in, but no ground wires on it.
Old 07-28-2007, 06:03 PM
05 GSXR 1XXX's Avatar
that backfire was the rings twisting and lodgin the pistons to the walls... j/k
doesnt sound like you missed anything. if the car starts it will start again unless somthing was unplugd.
im sure someone will chime in with the solution! good luck!
Old 07-28-2007, 07:15 PM
cals400ex's Avatar
there are 3 grounds on the back of the drivers head. 2 of them go to the same bolt. there are no grounds on the back of the passenger head. one of the bolts has a wire holder on it, just to hold some wires. the other one holds the tranny dipstick in place.
Old 07-28-2007, 07:39 PM
98Camarod's Avatar
Ignition relay? Switch your fan 2 relay for the ignition relay and see if you get anything out of that.
Old 07-28-2007, 09:25 PM
thosewhohatedmecreat's Avatar
i did some work on my engine and hooked the coils back up backwards, make sure the wires are right side up lol.... same with the fuel injectors..
Old 07-29-2007, 12:06 AM
I didnt remove the coils from the valve covers, no way to switch them...
Old 07-29-2007, 12:14 AM
2000TurboVert's Avatar
Have you checked all your fuses?
Old 07-29-2007, 12:15 AM
If you didnt, get a voltage meter and see if your getting power to the ignition relays and fuses.....
Old 07-29-2007, 12:17 AM
eallanboggs's Avatar
Back to basics. Fuel, spark, compression. Fuel pressure at fuel rails says fuel pump is OK, but what about the injectors? Are they being pulsed? Coil packs weren't removed from the rocker covers, but are the individual coils receiving the primary signal at the correct time to give you spark on the compression stroke? Separate this into either a fuel or spark problem then work backwards to the solution. How many ground does one engine need. Apparently some engines can never get enough ground. If you changed the lifters the heads and intake came off so the number of things you could have done to cause this problem are too numerous to list. Were you careful in handling the intake? You could have damaged a sensor. Do you have spark? Are the injector firing? Narrow it down and work backwards.
Old 07-29-2007, 02:13 AM
Psychopjv's Avatar
backfiring is what it likes to do when the cam sensor isn't plugged in/or broken. motor spins over freely though? positive timing marks were aligned? crank sensor in? no massive vac leaks? as stated we could go on for days.
Old 07-29-2007, 10:03 AM
I'm going to try another cam sensor today and i'll let you guys know the results.
Thanks for all the help.
Old 07-29-2007, 10:14 AM
LS1powerhouse02's Avatar
make 100% sure you lined the dots up!!! if not you may not want it to start!
Brent
Old 07-29-2007, 10:33 AM
The dots were lined up, and i also spun it over by hand with the plugs out to check it. I have a pretty giant cam in there (ms4), so if there was a PTVC issue from misaligned dots, I would have known
Old 07-29-2007, 03:32 PM
Swapped out Cam sensor, and I saw a broken head ground.. Ran an extension to the pass head for it...
Started up first try. It idled GREAT @ 1100.. then it got hot and just shut off, lol. Now it doesn't idle for ****. I guess I was a little too excited when an untuned ms4 idled well. LOL.
Old 07-29-2007, 03:37 PM
98Camarod's Avatar
glad to hear you got it started
