LS1 Build in progress. Any opinions?
Old 10-13-2007, 09:34 AM
flynlow3's Avatar
Default LS1 Build in progress. Any opinions?
I pulled my motor out of my c5 because the tranny was being rebuilt. I figured since I upgreaded the tranny and went with a stall that I might as well freshen up the motor. Did I make the right choices? This is what I went with thus far.
I put new chelvite 77 cam and rod bearings in it.
New Ls2 style timing chain
melling 10296 oil pump
I drilled the lifter cups and upgraded to 02 lifters that were inclosed.
ls1 hotcam
5.3 heads with larger intakes cut. Comp valve train and 1.8 stainless roller rockers and hardend pushrods.
28.8 lbs injectors
ls6 intake
my goal was to build a fairly stout motor that would be reliable too. are there any weak points I should take care of now while I have it apart?
thanks
Jeff
Old 10-13-2007, 11:32 AM
slowec's Avatar
rod bolts!
Old 10-13-2007, 12:16 PM
BerryWS6's Avatar
I would do head studs too
I hate cleaning those dam head bolt holes! with studs you dont have to do it ever again (if you swap heads later) Plus there much stronger than stock
Old 10-13-2007, 12:43 PM
1_bad_TA's Avatar
1. ARP rod bolts, head studs, main bolts or studs
2. Port and polish the Throttle body or get a new one. Example: BBK, holley, fast, etc...
3. Since you have it apart and are replacing bearings, do the mains with clevite 77's
Old 10-13-2007, 01:57 PM
flynlow3's Avatar
I didnt want to replace the rod bolts because I was told if I went with arp that I would have to pull the rods out. If I placed arp bolts in them that they would be thrown out of round and they would need to be honed. any advice? In how to build a hp ls book it stated that the 99+ years had good rod bolts, rods and pistons.
Old 10-13-2007, 02:25 PM
1_bad_TA's Avatar
If the engine is out of the vette and you have the heads off, why not replace them?
Yes the LS1's had good pistons,rods,cranks, rod bolts, etc from the vactory.
Old 10-13-2007, 02:44 PM
flynlow3's Avatar
I am replacing the head bolts. Just not the rod bolts.
Old 10-13-2007, 02:46 PM
1_bad_TA's Avatar
Well, good luck with your build either way.
Old 10-13-2007, 04:02 PM
68chevypu's Avatar
I replaced rod bolts in my car, just did them one at a time, and havent had any problems. Although there arent alot of miles on them yet I have spun it right to the rev limiter several times and noticed nothing in my oil.
But you could be right
Old 10-14-2007, 01:26 AM
flynlow3's Avatar
68chevypu
What type of rod bolts did you use?
Old 10-15-2007, 07:18 PM
BAN-LS1's Avatar
i used katech with the engine on a stand
