How do I drop the oil pan??
Old 11-20-2007, 03:23 PM
stevied916's Avatar
Default How do I drop the oil pan??
I am changing the oil pump and need to lower the pan not remove it. I am using the install guide on ls1howto.com but the pan seems stuck on there. I removed the 12 bolts...the 13th one isnt on mine I'm guessing because it's a 98. I even went to the dealer and got a schematic to see where all the bolts are. What is the easiest way to pop the pan off without messing anything up??
Old 11-20-2007, 03:26 PM
cherryelky305's Avatar
if you have an auto, sometimes the pan can get hung up on the transmission lines. Mine did when the motor was still out of the car, so that could be something to look for.
Old 11-20-2007, 03:27 PM
stevied916's Avatar
Mine's a m6...it just seems like it is stuck but I wont want to break anything prying the **** out of it to come off
Old 11-20-2007, 03:31 PM
Black FormulaLs1's Avatar
www.ls1howto.com maby?
Old 11-20-2007, 03:33 PM
stevied916's Avatar
Originally Posted by Black FormulaLs1
I am using that...read my post
Old 11-20-2007, 03:46 PM
massls1guy's Avatar
Did you get the 2 long skinny bolts at the back of the pan? Did you get the two thicker bolts that go from the bell housing into the back of the pan?
Old 11-20-2007, 04:34 PM
stevied916's Avatar
I got it...it was the bellhousing bolts which the writeup didnt mention
Old 11-21-2007, 06:48 AM
blkbird's Avatar
I had the same issue when i did my cam.
Old 11-21-2007, 07:19 AM
slow trap's Avatar
the oil pan is very sturdy. maybe just try using a flat screwdriver and slightly tap it in between the oil pan and the gasket/block and try not to hurt the gasket. when it breaks loose it will probably drop right down.
Old 11-21-2007, 11:06 AM
5.3LJimmy's Avatar
I have seen this a few times. I wish someone at LS1howto would update the guide to include that step. Those oil pans ain't cheap, and prying down on it with 2 bolts still attached is asking for a disaster.
Old 11-21-2007, 06:51 PM
eallanboggs's Avatar
If ALL the bolts are out try a rubber mallet in the corners.
