Who has had P2V problems with 230ish cam
Old 12-28-2007, 02:49 PM
ssheets's Avatar
Default Who has had P2V problems with 230ish cam
Who in here has firsthand knowledge of piston to valve contact with a 230ish cam and smaller 5.3 or similar heads?
I've heard hundreds of warnings, but it seems that cams such as the F14 or other 230ish duration ~.600" lift do clear.
Just curious, I wouldn't do it again without measuring to make sure. There's noting like knowing instead of guessing.
Old 12-28-2007, 05:09 PM
quick346's Avatar
I can tell you this a 232/234 xer barely turned over without hitting with afr 205's 59cc
with a stock gasket. maybe .020 intake . I would plan on flycutting but don't know what the valve drop is on your'e heads and this cam is xer lobe's . all i can say is check it
Old 12-28-2007, 06:02 PM
snatch's Avatar
I have unmilled 5.3 stage 2.5 heads (63-64cc I think), stock MLS gaskets with a torquer v2 112+4 cam. Apparently all the PRC heads with larger valves run the 2.02 and not the 2.04 but their site doesnt reflect that.
With an LS6 intake, 80mm TB, 25% underdrive pulley, pacesetter LT's, B&B 3" Tri-Flow, Vig 3200 and 3.42 rearend I put out 415rwhp unlocked.
HTH,
Shane
Old 12-28-2007, 06:10 PM
99mongooSS's Avatar
I never had an p2v problems with my MS4. Its bigger than the f14, isn't it?
Old 12-28-2007, 06:24 PM
quick346's Avatar
I think it depends more on how aggressive the lobe is more than the duration @.050
like a comp xr vrs the xer will have 2 diff ptvc #'s with the same duration and lift due to how fast they come off the seat.
a ms 4 has big duration and is made to have good ptvc .
just saying don't take just duration as the only facter on how big you can go
aslo doe's never had problems mean never checked ? or checked and never had a problem?
Old 12-28-2007, 07:38 PM
SOMbitch's Avatar
I was on the phone with TEA about a set of 5.3 stage 2 heads earlier this week and was told not go over 228 duration and run stock GM head gaskets to assure PTV clearance without flycutting. This was unmilled. Kinda surprised me. TSP will recess the valves a bit on their 5.3's if you ask them to. It will give more clearance but it will affect flow a little also.
Old 12-28-2007, 09:48 PM
LSX Mechanic
Damian's Avatar
I've ran a 230/232 Futral Motorsports cam with TEA 5.3's shaved .025 without a problem. Installed a 232/236 cam also on those same heads without a problem.
About to install a FMS 230/234 cam on another set of 5.3's.
Saying you can't go over 228 in durations is kind of silly especially on an umilled head.
Old 12-28-2007, 10:52 PM
ssheets's Avatar
Yeah, I ended up with .100"/.180" clearance with the F14 and 5.3s with 2.02"s milled .003"-.005" But I wouldn't do it blindly, as stated above, it is really a function of ramp design more than lift or duration...it's like voltage and amperage, you can't have one without the other though.
And builders are always going to tell you the conservative plan, that's why guys that want to push it more take the time to measure and research. Questions like this help define the statistical averages, but there's always that oops factor. Now I'm thinking about maybe bumping my CR up with a .040" gasket and maybe shaving another .005"-.010" off.
We'll see how it runs in summer heat first though.
Old 12-29-2007, 04:21 AM
PREDATOR-Z's Avatar
Are you sure you calculated your PTVC correctly, those margins seem large for a 232/234 112 LSA
Old 12-29-2007, 01:01 PM
SOMbitch's Avatar
I am just telling you what Mike from TEA said. As noted in my post I was surprised too.
Old 12-29-2007, 02:44 PM
seawolf18's Avatar
im running a 228/232 cam with PRC 5.3L stage 2.5 heads. No PTV issues here.
Old 12-29-2007, 03:54 PM
badass99ss's Avatar
I just purchased patriot LQ9 heads and a 232/240 .595/.608 cam. Bob @ EPP told me no issues with PTV clearance.
Old 12-29-2007, 04:13 PM
JPH
JPH's Avatar
crane HR5 lobe 228/232 .600/.600 112LDA/107ICL 7*IVO with .030 milled LS6/#243 heads, -.012 deck, .051 thick head gasket with crane 1.7 quick lift rockers on top(this is what hurt me the most), I had .012 intake and .109 exhaust PTV.
Old 12-29-2007, 10:32 PM
silverLSWON's Avatar
buddy of mine ran tv2 on 112 lsa with gm 5.3 heads milled .10 and a stock head gasket. no ptv problems
Quick Reply: Who has had P2V problems with 230ish cam
