German Castrol
Old 08-18-2008, 12:56 PM
smokintiresz28's Avatar
Smile German Castrol
Just wanted to throw this out there, I just switched from mobil to GC 0-30 and I will say my motor has never been so quiet and my oil pressure at operating temp is great compared to mobil 1 considering where I live in Texas it is HOT so I said all that to say this if you ever thought about it do it make the switch.
Old 08-18-2008, 05:06 PM
DaddySS's Avatar
Old 08-18-2008, 05:29 PM
Weezzer's Avatar
My oil analysis are so good on the GC that I brought 47 quarts with me when I moved from Corpus Christi a couple of years back.
I'm still getting good UOA reports back at 6000 mile oil change intervals.
Old 08-18-2008, 07:47 PM
jermzz's Avatar
what kind of filter are you using?
Old 08-18-2008, 07:54 PM
I was going to use kn 1017 or 1007 but were out of stock so used the good old delco
Old 08-18-2008, 09:23 PM
KMS.1320's Avatar
Some engines are going to like different oils. Mine drank M1 5w30 like water. Tried the GC for 2 changes, a little quiter, but it wasn't any more pressure and it still drank it. My last 2 changes are with 10w40 RP XPR, and the engine quited down, I add MAYBE half a quart every 5k miles between changes.. it just feels smoother. It is a higher mileage engine, so no doubt the clearances have gotten a tad larger over time, and the thicker oil was welcome.
Old 08-18-2008, 09:34 PM
I was going through m1 one quart every 1500k and when really hot like 100 degrees plus outside with 80% humidity which makes it feel 130 my car at a red light might have 10 psi oil pressure now stays over 40psi all the time and MUCH quieter.
Old 08-18-2008, 09:49 PM
Weezzer's Avatar
I bought several Delco PF-59's with the anti-drainback valve just prior to them being discontinued.
I'm still using those, I think I have about 3 or 4 left.
Old 08-18-2008, 10:02 PM
bballr4567's Avatar
I switched from the M1 10W30 the previous owner was using over to GC and was REALLY impressed with it. It made the car way quieter and ran smoother as a result. Had a tad more oil pressure also. The friendly neighborhood autozone had it in stock too. Had to dig through all the 0W30 to find it and they had 6 quarts and it was on sale for $5.19.
Question for you guys. If the car is sitting for 2 and a half months would you change out that oil? It was run MAYBE a total of 100 miles on the new oil.
Old 08-18-2008, 10:06 PM
hell no
Old 08-18-2008, 11:09 PM
Bad06SS's Avatar
What weight mobil one were you using? My car seems to really like mobil 1 0w40.
Old 08-19-2008, 10:09 AM
WhiteFormula98's Avatar
+1 for 0w40
Old 08-19-2008, 12:08 PM
wht01ws6ta's Avatar
Yeah I have a stockpile of GC 0W30 at my house too Patmon tested out Penzoil Platinum and said it is very good oil too, and quite a bit cheaper so I will probably go with that when the GC runs out.
Old 08-19-2008, 12:22 PM
KriegerEhre's Avatar
NOOOOOOOO Penzoil is a HORRIBLE oil!!! I'm sure like 20 other guys can back me up on that. there's a reason why it's a bit cheaper.
Old 08-19-2008, 12:27 PM
TXZ28LS1's Avatar
not running that german 0w stuff. but i am running castrol syntec 5w-40 and i love this stuff. my car has no oil consumption issues at all or anything. very good oil.
Old 08-19-2008, 01:42 PM
I have been a M1 freak for a long time like die hard could not tell me any different but now that I have seen the results of GC I feal as if I broke out of the M1 matrix ha ha.
Old 08-19-2008, 03:57 PM
Redlinez's Avatar
My h/c TA drank the Supertech Synthetic 5/30. I just switched to Valvoline 10/30 too see what happens. Patman was an oil researching freak and used to hang out on bobistheoilguy dot com. I may go back to the GC if others have experienced oil consumption that stopped after going to GC as I was using 1 quart every 1200-1500 miles.
Old 08-19-2008, 05:21 PM
Its ok man to let it out, you are among friends, we feel your pain.
Old 08-19-2008, 08:05 PM
KMS.1320's Avatar
The new Penzoil Platinum is actually a very good oil which has done exceptionally well in used oil analysis with the LS1. You're going to have a real hard time finding people to agree with you that it sucks.
Old 08-20-2008, 08:19 PM
I dont know
