Another Guess the hp before the dyno???
Old 10-02-2008, 07:43 PM
Sammyboy's Avatar
Default Another Guess the hp before the dyno???
I'm about to finish my head/cam assemble on my 2001 SS Camaro (M6) and I was just wondering what to expect number wise. Here is a list of my modifications:
MS4 Cam
TSP LS6 stage 1 heads
Crane Cam double roller timing set
ARP head Studs
Victor Junior intake manifold
Edelbrock fuel rails and instillation kit
Nitrous outlet Elbow w/ 92mm flange
Fast (big mouth) 92mm Throttle body
SLP 85mm Mass Air Flow sensor
Fast Toys 85mm lid
K&N drop in filter
LS6 Valley cover w/ pvc rerouting
QTP long Tube o/r headers with velocity merge collector
TSP True duals
Chromoly pushrods
42lb fuel injectors
Sammyboy is offline
Old 10-02-2008, 07:47 PM
conan's Avatar
430 rwhp 400 rwtq
conan is offline
Old 10-03-2008, 08:23 AM
Sammyboy's Avatar
Friday bump!
Sammyboy is offline
Old 10-03-2008, 08:33 AM
wht01ws6ta's Avatar
Originally Posted by conan
430 rwhp 400 rwtq
I was thinking about the same thing but probably a little more at least for the HP number.
You almost done with the install?
wht01ws6ta is offline
Old 10-03-2008, 11:25 AM
Sammyboy's Avatar
Yea....I'm going to wetsand it today and finish assembly next weekend. https://ls1tech.com/forums/showthrea...=922490&page=5
Sammyboy is offline
Old 10-03-2008, 01:18 PM
wht01ws6ta's Avatar
Cool man! So you went with the Vic Jr. instead of the FAST 90 you originally were ordering I guess?
Old 10-03-2008, 11:47 PM
Ehatcher's Avatar
430-450. Better flowing heads will result in higher numbers. There is a guy with an MS4 with Terminator heads that went 442 whp. Those are some of the better heads you can purchase. It also comes down to how fresh the engine is.
Ehatcher is offline
Old 10-04-2008, 01:50 AM
sf35thle's Avatar
sf35thle is offline
Old 10-04-2008, 07:36 AM
Administrator
unit213's Avatar
Put her on the dyno and post up the results in the Dyno section.
Good luck!
Thanks.
unit213 is offline
