Gen III cam work in Gen IV?
Old 06-24-2009, 01:21 PM
The stunningman's Avatar
Default Gen III cam work in Gen IV?
Will a gen III cam cam work in a Gen IV engine? I am removing the VVT and changing to the LS2 front cover and cam timing gear?
Old 06-26-2009, 09:03 PM
coleman1's Avatar
im pretty sure they do if you do what you just said.. but it be a lot easier to just use a cam for it to begin with no??
Old 06-27-2009, 12:37 AM
HSV-GTS-300's Avatar
Yes you can use a Gen3 cam in a Gen4. You just need to buy the timing gear with 3 bolt holes, 3 cam bolts, and you should change the brown chain tensioner to the black chain damper.
From This.
To This.
Old 06-27-2009, 06:31 AM
Petraszewsky's Avatar
^^^Also the chain sprocket pictured above is for a 4x cam sensor which means you would have 58x reluctor wheel...with a 24x reluctor wheel you should get a 1x cam sprocket....
Old 06-27-2009, 06:50 AM
3 bolt 1x cam gear for 24x
Old 06-27-2009, 07:24 AM
LS1MCSS's Avatar
I kept the brown chain tensioner on my 418. Either one will work. If your engine has the brown one, keep it.
Old 04-30-2010, 06:28 PM
ss.slp.ls1's Avatar
Why does everyone say to change the timing chain tensioner? I need to know before I button up the front of my car.
Old 04-30-2010, 07:07 PM
The brown/yellow tensioners often break
Old 04-30-2010, 07:26 PM
ss.slp.ls1's Avatar
But I have been reading that the black one has a different bolt patter and will not bolt up to the '07+ blocks...
Old 04-30-2010, 07:59 PM
The black damper definately fits in the Gen 4 blocks used in 2008 & 2009 Pontiac G8-GT's.
The block itself in those has the same block casting number as an LS2.
Broken.
Old 04-30-2010, 08:02 PM
ss.slp.ls1's Avatar
^^^Thanks for your response. I will go ahead and order the black one.
Old 04-30-2010, 09:47 PM
cam
cam's Avatar
I've read a lot of mixed info on which tensioner is better. At least the newer one adds some tension
Quick Reply: Gen III cam work in Gen IV?
