SUPPLIERS of SHORT BLOCK for BOOST
Hi all, looking through the maze of people and suppliers of LS short and long blocks is migrane material. In addition i am also from Australia so my extended knowledge of local GOOD suppliers is somewhat limitted.
My question, who are the shops/people i should talk to in regards to a short/long block for my TT set up. Potenually looking at LS2/LQ9 408-414 with forged rotating essembly?
It is hard as i have heard locally and had advice not purchase through certian companies, so you direction would be appreciated.
Thus far looking at
texas speed LQ9 408 for $3800
Schwanke LS2 415 $4489
Golen engines LQ9 408 $4999
regards
paul
Thus far looking at
regards
paul
The key in comparing different companies is first to make sure all parts are the same - ie pistons, rods, crank, block etc. For long block, what are heads and who ported them. After you get components identical, I suspect most suppliers pricing will be reasonably close. Recommend you determine what you want first, then shop for price, quality and reputation from suppliers.
Good luck,
Good luck,
Give us a look Paul,we have built some of the fastest boosted ls engines in the world including Phil's Thomas's drag radial lsx powered mustang that hold the record for the fastest single turbo radial car in the world.
we got a sale going on right now
https://ls1tech.com/forums/sponsor-s...lock-sale.html
We offer HKE precision racing engines. Our 408 for boost start at $4675 but it really depends on the amount of boost and application. I sent a pm. Here are some comments about HKE engines
https://ls1tech.com/forums/generatio...l#post12666619
LS1Tech Premium Sponsor
Thanks for including us in your list of potential builders. If your in the area & would like to see what goes into a TSP short-block & what makes our short-blocks special please give me a call! I always like the opportunity to show off what actually goes into a TSP short-block. Just because our prices are competitive doesn't mean we skip any corners! I'd absolutely put a TSP short-block against any company in the country.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
