VVT removal on L76
Old 03-31-2010, 07:56 PM
Nova 404's Avatar
Default VVT removal on L76
I am looking at a L76 6.0 for a carb'd application and was what is involved in removing the VVT.I have searched and not found much information on this.I was planing on a cam swap anyway but is it as simple as swaping cam,cover and gear/chain??
Old 03-31-2010, 08:09 PM
3pedals's Avatar
yes...
Old 03-31-2010, 09:46 PM
IHEARTLS1's Avatar
you don't even need to change the cover. change the cam and the sprocket and you are done.
Old 03-31-2010, 09:56 PM
3pedals's Avatar
you need to change the cover because non VVT top gear is not as "tall". LS2 cover is needed so cam sensor is close enough to get a signal from the top gear.
Old 04-01-2010, 07:05 PM
Nova 404's Avatar
It also has Active Fuel Managment,so does this mean I need to change the lifter trays and lifters as well?Any idea how much money is involved in converting to conventional parts?
Old 04-01-2010, 07:34 PM
IHEARTLS1's Avatar
need to change the liters. doubt the trays have to be replaced, but look up the part numbers for both engines.
Old 10-23-2011, 08:34 PM
toytech93's Avatar
Need to refresh an old topic !
-Is the cam swap necessary to run the L76 with a carb? I was hoping to wait on funds before cam swap.
- is the oil pump change necessary if swapping oil pan? I read the DOD high volume oil pump will suck the small pan dry.
Old 10-24-2011, 09:48 PM
3pedals's Avatar
I ran the OEM cam in my LY6(VVT motor), the correct top cam gear for a single retaining bolt is the only difference, I found mine on an 08 5.3.
my stock 6.0 LY6 w/ vvt removed(but still stock cam), and converted to carb propelled my 67 camaro to a 12.59 @ 109
Old 07-10-2014, 01:20 PM
Sn95ls's Avatar
When you changed your cam gear did you change your timing cover
Old 07-10-2014, 01:41 PM
lil john's Avatar
3 pedals knows more than me on this...but TSP sells the entire kit.
Quick Reply: VVT removal on L76
