VVT delete 2x and 4x cam sprocket differences
Old 11-19-2010, 08:29 AM
The stunningman's Avatar
Default VVT delete 2x and 4x cam sprocket differences
I used a LS2 2x 3 bolt cam sprocket and LS2 cover when I removed the vvt from a 2008 LY6 with zero problems. I did the VVT delete and changed it over to carb using a MSD 6012.
Most people changing over to carb are using the 4x 3 bolt cam sprocket and LS2 cover when they remove the VVT.
My 2008 engine had to have had a 58 crank reluctor.
I am just wondering why it works fine both ways with the 6012 and carb converted?
Whats the differences in the 2X and 4x cam sprocket, outside the obvious?
Old 11-19-2010, 09:29 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
As long as the 1X or 4X reluctor on your cam gear (and 24x or 58x on the crank) matches what your engine controller or PCM is programmed for and expecting, it'll run fine. I have never seen any empirical evidence that one is more stable or able to run better than the other, all others being equal.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 11-21-2010, 01:52 PM
Are the GEN IV 4x and the 2x LS2 timing covers the same?
Old 11-21-2010, 02:50 PM
3pedals's Avatar
I am using a 4x cam gear and GenIV non-vvt cover on my LY6 vvt delete. I am also using a msd 6012 and a carb.
My MSD refuses to accept the cam sensor signal. It will start, but it just guesses at #1 cyl tdc. It will sometimes guess wrong and backfire while cranking. Laptop shows cam sensor fail, but I know it is good.
How is your 6012 working with the 2x cam gear?????
Old 11-21-2010, 09:04 PM
Perfect... never a problem. I have since sold the truck and work on it exclusively for the owner.
What you had mentioned, is one of the reasons I asked. I'm wondering if your problem might have a little to do with reusing the LY6 cover sensor on the late model timing cover or maybe some mismatch otherwise.
Old 11-21-2010, 09:28 PM
3pedals's Avatar
maybe I should try a 2x gear/sensor? I thaught that the msd would be looking for the 4x signal since it is designed for the 58t crank sensor.
I guess the real question is: WHAT SIGNAL DOES THE 6012 BOX WANT TO SEE????
Old 12-22-2010, 02:35 PM
Hank Peabody's Avatar
Hi 3pedals, did you ever figure this out, I am about to go down the same road and would love to know. Thanks!!
Old 12-22-2010, 07:08 PM
3pedals's Avatar
car is hibernating for the winter, I will start on it again around march. I have not tryed the 2x cam gear.
I am interested in your blow through s400/lq4 setup, looking at doing the same on another car I have.
Old 12-22-2010, 07:27 PM
I am doing the exact same thing to this LY6, blow through and MSD box and turbo. This stock LQ4 with little cam makes obscene power! Im going to do the same thing in a 400# lighter car with the LY6, I have no idea where to start with what cam to use though!! No one is turboing stock LY6s as far I can tell, not sure why. Thanks!
EDIT: Did you see this, it looks like the 6012 box should expect the 4x sprocket, why the hell is it not working for you?! That is worrisome! http://www.lingenfelter.com/page/ls-...lector-id-page I guess the sprockets are cheap enough to try the different ones but man that is irritating!
Is it required to get a different non-vvt front cover? Which one to get, is it an early 58 tooth LS2 cover? Thanks again!
Old 12-22-2010, 10:09 PM
3pedals's Avatar
yes, non vvt front cover w/ cam sensor is required to eliminate VVT. I got my cover off an 08 5.3 from a wreker.
Quick Reply: VVT delete 2x and 4x cam sprocket differences
