Looking for a cam for my 2011 Tahoe
Old 05-19-2014, 06:27 PM
Kalehuawehe2646's Avatar
Default Looking for a cam for my 2011 Tahoe
Hey all!!! I have been trying to research for the best cam for what I want... I have intake/LT Headers/Exhaust/Tune. I am going to port and polish my stock (799) heads and get a stall... So I am wondering what cam would be best for me... I want a more torquey cam that is more down low to help move my heavy A$$ Tahoe. I am going to delete to DOD/AFM when I install the cam. Compcam suggested a 214/224 .500/.500 115lsa cam but I was looking and found anther compcam 219/235 .607/.621 113°. This one started lower in the rpm range and ended at the same as the first one...
But Iʻm open to all suggestions!!! Thoughts? Thanks all!!!
Old 05-19-2014, 06:42 PM
98RedZone's Avatar
That is a wide duration split. They have a LSr cam with 219/227 112.
Old 05-19-2014, 10:50 PM
99Bluz28's Avatar
I you don't mind more aggressive cam lobes the go with the CompCams 54-455-11 (215/223 112lsa+5, Lift .604"/.610" ).
http://www.ws6project.com/user_stor/...lsa-4-8l-5-3l/
For something more valvetrain friendly(214/222 112lsa+4, lift.595"/.566") I'd go with Comp Cams custom grind with: 214 LXL lobe #13155, and 222 Xtreme RPM (high lift) lobe #3714.
http://www.texas-speed.com/p-161-com...-camshaft.aspx
Cam Motion can also grind you a similar custom cam, except with softer cam lobe ramp rates, and even longer valvetrain life.
http://www.mcssl.com/store/cammotion/custom-camshafts
http://www.cammotion.com/lobe-list.php
Old 05-20-2014, 05:09 AM
Thanks for your help 99Bluz28!!! But Iʻm pretty sure that my cam is the single bolt and this is a three bolt... Iʻm a nooby when it comes all this but what I do know is that my engine in my Tahoe is the (LMG) 5.3L. So I have to make sure that the cam will work in my Tahoe... But thanks for the help!!!
Old 05-20-2014, 11:59 AM
1989GTA's Avatar
"But Iʻm pretty sure that my cam is the single bolt "
Do you have VVT?
Old 05-20-2014, 12:16 PM
No VVT...
Old 05-20-2014, 12:46 PM
bugy's Avatar
it all depends on truck purpose, as you mentioned more end low torque, what converter rpm will be installed? only daily drive? if so i would go with compcams suggestion.
Old 05-20-2014, 12:54 PM
It is my DD and a converter will be installed (still trying to figure out which one) however I want my 0-60 and 60-100 to be mean... Also want a choppy sound too... The second comp cam I mentioned is #146-456-11
Old 05-20-2014, 01:58 PM
bugy's Avatar
you don't want to use that 146-456-11 since it is designed to work with rectangular heads port, also should've mentioned choppy sound desired, you will need a specific cam for that sound, if you are able to get a chain set go for 3 bolt type, there you can choose a wide cam's amount.
Old 05-20-2014, 02:27 PM
Okay I see... I have cathedral ports... Yes I would like choppy sound. So you're saying switch to a three bolt? Are there any other pros/cons to three bolt set up?
Old 05-20-2014, 06:15 PM
bugy's Avatar
well, some say 3 bolt have more rigidity and stability to sprocket and you have more camshaft to choose with 3 bolt, but if you don't want to spend more money look for a single bolt cam with specs required.
Old 05-21-2014, 12:31 PM
Okay thanks for the info!!! I think Iʻm gonna stay with a single bolt since this is a cheap build and the fact that I am having a mechanic friend help me and donʻt want to be drowning him!!!
Old 05-22-2014, 09:51 AM
bugy's Avatar
camshaft suggested by comp cams is great for your need it will give you a great low end torque and mid response, you just need to look for a tighter LSA to get that choppy sound.
Old 05-22-2014, 12:39 PM
Is that possible? How do I go about doing that? I know that the choppy sound is for more high end but is it still possible for what I want?
Old 05-22-2014, 03:25 PM
bugy's Avatar
it is certainly possible, a did a little research to compcams catalog and couldn't find something for your request (because of center bolt cam) but i'm pretty sure there is something out there for your specific demand, contact compcams if there's nothing available you can get a custom one, try other brands too, remember to mention your needs..
Old 05-22-2014, 05:12 PM
Thanks bugy!!! That was the one that compcam suggested and I also talked with cam motion and they suggested a similar cam... Who else can I try?
Old 05-22-2014, 05:14 PM
LivernoisMotorsports's Avatar
pm sent to "Kalehuawehe2646"
Quick Reply: Looking for a cam for my 2011 Tahoe
