Identify this part that was in my oil pan
Old 07-16-2014, 01:58 PM
5 Liter Eater's Avatar
Default Identify this part that was in my oil pan
Cross posting from 3rd gen:
https://ls1tech.com/forums/generatio...y-oil-pan.html
Old 07-16-2014, 04:41 PM
Briou's Avatar
You may want to pull the valve covers and take a look....Not too sure what it could be though...
Old 07-16-2014, 04:48 PM
Definitely pulling the covers tonight as well as going through the drained oil and filter.
Old 07-16-2014, 05:18 PM
KCS
Moderator
KCS's Avatar
Any spacers under the Jesels?
Old 07-16-2014, 05:25 PM
JS01's Avatar
Thats pretty small.... only thing I can even think of that small is this but still dont think this is it....
Old 07-16-2014, 10:22 PM
LLLosingit's Avatar
Is that a split ring or solid in the picture? Edit: I found other pictures and that is a split ring retainer... That has my vote JS01
Old 07-16-2014, 10:32 PM
Randy WS6's Avatar
It might be a timing chain link
Old 07-16-2014, 11:16 PM
Everything in the valve train is intact, split rings on all the rockers.
Jez now that you mention it, it could be part of a timing chain link. ****...
Old 07-16-2014, 11:36 PM
Damnit! I just had the cradle down to rebuild the turbos. And just before that to pin the balancer. ****!
Old 07-16-2014, 11:38 PM
Randy WS6's Avatar
It might not be the chain . Find a old one and compare it first
Old 07-17-2014, 12:55 AM
The ID doesn't jive with the outer link but the inner links likely have a bigger ID. The thickness of one of the inner links is within .001" of this piece.
Going to pull the intake and valley pan and I should be able to get a decent look at the chain.
Old 07-17-2014, 01:39 AM
Ari G's Avatar
If you have a double roller,the oil pump needs to be cleranced on the back or the chain will make contact and come apart,did you see a drop in oil pressure before?
Seen this before and only thing left of that motor was the balancer...
Old 07-17-2014, 01:41 AM
The pump was spaced with spacers that came with the timing set and the cover clearanced. Oil pressure seems fine.
Old 07-17-2014, 02:30 AM
Ari G's Avatar
Even with the spacers it still will touch if not cleranced
Old 07-17-2014, 06:43 AM
Randy WS6's Avatar
Did you build the motor from scratch or did you get the motor already built, It could have been in the engine from a previous build, different brand chains may have different link sizes, Just a thought .
Old 07-17-2014, 08:32 AM
It's an HKE short block that I put together. The chain was brand new although I don't remember the brand right now. It's been running for about a year now.
Old 07-17-2014, 11:13 AM
KCS
Moderator
KCS's Avatar
This is what I was thinking...the edge of a shim shown in the bottom of the photo. Just a WAG though.
Old 07-17-2014, 11:56 AM
Randy WS6's Avatar
I found this , Does it look something like the piece, Read below the pic on how it broke !!!
http://www.hotrod.com/techarticles/e...photo_11.html#
[URL="http://http://www.hotrod.com/techarticles/engine/hrdp_1008_dick_landy_484_hemi_engine/photo_11.html#"]
Old 07-17-2014, 10:02 PM
No shims under the Jesel setup.
Didn't work on it tonight. Should have the intake and valley cover off this weekend and will take a look at the chain.
Old 07-18-2014, 08:52 PM
Well, found it.
Plus this other guy getting ready to give up the ghost.
Thanks to Randy for saving my motor!!!
Quick Reply: Identify this part that was in my oil pan
