What is best Ls Hyd roller lifters?
Old 08-15-2014, 10:07 PM
dr ls7's Avatar
Default What is best Ls Hyd roller lifters?
I got a big dollar 427ci with biggish bullet hr cam 264/277 and 650 ish lift. Had it on dyno and due to engine builder forgetting to tighten a cam bolt it failed at very low revs. It lasted 1 pull under light load, low timing, and old fuel
It made 650hp and 580 ft lbs at 6000rpm. Expected power is high 700's. It's making 80+hp every 500rpm from 4000.
Engine will rev to 8200+ rpm.
We had 5206 morel link bars and bullet cam tech has suggested to run 5206 high rpm lifters, the only problem is that I've heard if so many 5206 failures.
Old 08-16-2014, 02:53 AM
Super Hulk Smash
JakeFusion's Avatar
The Hi-Po 5294 Morels would work... but they hate any sort of debris in the oil.
Given the RPM range, I'd look at short-travel lifters. Johnson and Morel both make them. I have the Johnson short-travel with axle-oiling in my car ST2126LSR.
Old 08-16-2014, 06:40 AM
Gray86hatch's Avatar
The 5294 or lunati high rpm. Reved mine 7700 with no issues.
Tim
Old 08-16-2014, 07:30 AM
FLYZNTN's Avatar
5206 Good
5294 Better
ST2126 Best
I know this because of all the time I spend at Holiday Inn Express.
Old 08-21-2014, 02:53 PM
SSSTANG#1's Avatar
I went with Morel 5058 HLT. Haven't started the engine yet though.
http://www.flowtechinduction.com/mor...raulic-roller/
Old 08-22-2014, 09:40 PM
CAMSTER's Avatar
Your build deserve a solid roller lifter cam as you will have control of your valve train rather than allowing springs to control, IMO venturing into professional rpm territory deserve better control tooling.
Ones you try em there's no going back.
Old 09-29-2014, 11:46 PM
03EBZ06's Avatar
Originally Posted by FLYZNTN
5206 Good
5294 Better
2126 Best
How are the 2126s better than say a 5294?
Old 09-30-2014, 10:55 AM
SStheBest's Avatar
This was exactly what i was thinking. For the kind of NA poer your making and trips at the track, id be looking at Jesel rockers.
Old 10-03-2014, 07:48 PM
Black_Phantom's Avatar
Billy Briggs built my motor it's Twin Turbo Hyd roller 427" Dart LsNext with MAST LS7 Heads and he Recommended The Comp Short Travel Link Bar Lifters 15956-16 so that's what we got.
Old 10-04-2014, 07:44 AM
FLYZNTN's Avatar
Different strokes for different folks but I'll say the axle oiling for the Johnson's makes them a better design IMO.
That said, you can't go wrong with any of the 3 listed....... although, like others have said, 8200 RPM for a hydraulic is a little dicey (didn't notice the RPM requirement the first time around).
Quick Reply: What is best Ls Hyd roller lifters?
