Cometic HG Dry or Coated?
Old 09-18-2014, 07:10 AM
6togo's Avatar
Default Cometic HG Dry or Coated?
So i have read some recommend coating the Cometic HG's with copper spray to help seal and i heard install them dry which is the best route?
New lsx block and Mast heads that is boosted if that matters!
Old 09-18-2014, 08:18 AM
KCS
Moderator
KCS's Avatar
I'm pretty sure Cometic recommends installing them dry.
Old 09-18-2014, 09:17 AM
allblowdup's Avatar
I always use permetex hitack. I will never install a set without it.
Old 09-18-2014, 10:09 AM
Super Hulk Smash
JakeFusion's Avatar
They say dry, but I put copper spray on mine because I didn't have a machined deck on my stock shortblock. No coolant leaks from mine.
Old 09-21-2014, 05:29 PM
6togo's Avatar
So when you guys spray them do you drill out the rivets and spray between layers or just the top and bottom?
Old 09-21-2014, 08:06 PM
Moderator
John B's Avatar
Cometic says use nothing and I have used half a dozen sets of them installed dry with zero issues.
Old 09-21-2014, 10:12 PM
6togo's Avatar
It seems like a 50/50 deal as far as coating goes!
Old 09-22-2014, 09:20 AM
allblowdup's Avatar
Nope just the sides that contact teh block and heads.
Quick Reply: Cometic HG Dry or Coated?
