custom order Diamond pistons question?
Old 09-28-2014, 04:11 PM
trevmust's Avatar
Default custom order Diamond pistons question?
anyone deal with Diamond for making custom pistons? or is that something I should take to a builder to ask for help with?
Old 09-29-2014, 02:27 AM
Jontall's Avatar
It's always better to buy an off the shelf piston and hone for its size. Custom pistons are expensive and take a long time receive. Only do it if you need something really special and if that's the case, take it to a professional engine builder.
Old 09-29-2014, 06:00 PM
JAH
JAH's Avatar
If there isn't an off the shelf LS piston, could you use a gen I piston? I would think you would have to have the valve reliefs re-machined. At what point does a piston become a custom piston?
Re-machining valve reliefs, changing the pin location, odd size bore, any of the three? Or other items?
Old 09-30-2014, 03:44 AM
Jontall's Avatar
The post is too random to answer... He is not saying exactly what's needed.
Old 09-30-2014, 03:47 AM
trevmust's Avatar
i want a cr of 9.5, and i cant get that with an off the shelf piston in the bore size i want. What do i do? (is that better?)
Old 09-30-2014, 03:48 AM
trevmust's Avatar
i need a -16cc piston and the closest i can find is -8
Old 09-30-2014, 06:51 AM
FLYZNTN's Avatar
JE sells a 4.075" x 3.622 (6.125 rod) -19.6.
JE Pistons
That's the closest I could find to a 4.075 x 3.622 -16 cc piston that is off the shelf.
I think Wiseco could build you a reasonably priced set of what you are looking for but, honestly, I've never bought a set. I'm only going by word of mouth so don't take that as gospel. That said, "reasonable" is a relative term. What I mean by it is 30-50% more then an off the shelf piece.
IMO, the best thing to do is contact the manufacturer directly or submit a form:
http://JE -Custom.pdf
http://Wiseco - Custom.pdf
Old 09-30-2014, 05:15 PM
trevmust's Avatar
that doesnt work. i need a 4 inch stroke piston.
4.075, 4, 6.125, 1.105
Old 10-03-2014, 07:32 PM
Black_Phantom's Avatar
With that odd CH plus 4.075" bore it's gonna be custom set.
you can contact Brian Tooley Racing for a custom set of wiesco, he is a dealer
Old 10-04-2014, 01:01 AM
trevmust's Avatar
sorry I need -18 (dish). whats the max bore on a ls3 block? I've heard that its 4.1, and anything below (4.1) as long as i can get it to give me a 9.5cr, i'm good with it. and i want to be able to supercharge it too, so the closer to 4.075 I am the happier i am lol
Old 10-04-2014, 01:10 AM
trevmust's Avatar
the form looks tricky, so when i'm ready I'll contact a builder about it, see what he says. Maybe he will even let me help put the engine together, cuz I'm kinda afraid to do it myself, but I don't want to be left out of the process.
Quick Reply: custom order Diamond pistons question?
