-28cc pistons w/70cc heads what's the compresion ratio?
Old 08-04-2007, 05:38 PM
phildo's Avatar
Default -28cc pistons w/70cc heads what's the compresion ratio?
As the title says looking to figure out if I got the compression ratio right. I figured it to be 8.5 to 1. It is on a ls2 stroked to a 402. Stock Gm multi layer. Probably .60 thick.
Old 08-04-2007, 05:48 PM
slow trap's Avatar
if i figured it right on stock cubes/gaskets i got 7.6
Old 08-04-2007, 05:50 PM
phildo's Avatar
Sorry it is a stroked ls2 so it is a 402.
Old 08-04-2007, 06:10 PM
ddnspider's Avatar
Received 1,736 Likes on 1,297 Posts
depending on gasket its roughtly 8.5
Old 08-04-2007, 07:14 PM
slammer454's Avatar
I got 8.2.
Old 08-05-2007, 03:49 AM
phildo's Avatar
Any one else? Different opinions.
Old 08-05-2007, 07:44 AM
OneQuickCoupe's Avatar
Are the pistons at zero deck?
D.J.
Old 08-05-2007, 09:47 AM
slow trap's Avatar
with the calculator i use i came up with 8.64 with pistons out .008 thou and with a .055 gasket. the only exact way to get it is to cc the heads and pistons to verify they are exactly what cc they suppose to be and but you should be in the 8.5x-8.6x range.
Old 08-05-2007, 10:07 AM
JimMueller's Avatar
I come up with 8.582 SCR using these figures:
Chamber: 70cc
Compressed gasket: .060
Gasket Bore: 4.000
Deck height: .008 above deck
Stroke: 4.000
Bore: 4.001
Piston volume: 28cc dish
Old 08-05-2007, 11:44 AM
99Fbody99's Avatar
4" bore x 4" stroke.
.051" compressed gasket thick with 4.030" bore
Zero deck
-28cc pistons
70 cc chambers
Quick Reply: -28cc pistons w/70cc heads what's the compresion ratio?
