LS7s suffering valve-train failures from mild after-market cams???
Old 07-14-2007, 11:41 AM
SideStep's Avatar
Question LS7s suffering valve-train failures from mild after-market cams???
Has anyone heard of LS7s (with LS7 heads) suffering valve-train failures from mild after-market cams??? (even with upgraded springs)
Old 07-14-2007, 11:48 AM
Haans249's Avatar
Do you mean the rocker arms failing and spilling their bearings? If so, i've heard it here and there, thats why I upgraded mine with the harland sharp mod.
Old 07-14-2007, 11:59 AM
NEVRLIFT's Avatar
I haven't heard much. Most of the rocker arms failures I've seen have been on bone stock ones.
Old 07-14-2007, 12:49 PM
LS1TECH Sponsor
Katech_Jason's Avatar
We have never failed any of our aftermarket combos. They are all tested on the valvetrain dynamics cell for valvetrain control.
Old 07-14-2007, 12:52 PM
OneQuickCoupe's Avatar
Jason, Do you have stock LS-7 rockers on those combo's.
D.J.
Old 07-14-2007, 12:56 PM
LS1TECH Sponsor
D.J.
Every one.
Old 07-14-2007, 01:34 PM
SideStep's Avatar
Originally Posted by Katech
Every one.
Are these LS7 rockers modified???
Old 07-14-2007, 03:30 PM
Ferocity02's Avatar
I've heard a few cases of the rockers failing, but it was due to insane spring pressures and improper geometry.
Old 07-14-2007, 05:08 PM
LS1TECH Sponsor
Nope. We have never failed a stock rocker in all development, durability, and aftermarket testing.
Old 07-14-2007, 05:23 PM
SideStep's Avatar
Very good news... thanks for the reply....
Old 07-14-2007, 06:44 PM
See5's Avatar
There have been TI intake valve failures however.
Old 07-14-2007, 08:59 PM
Louis's Avatar
And Lashpad failures as well as some valvespring failures, if you make it past the bearing issues that seems to be another engine killer.
Old 07-14-2007, 09:27 PM
bigblockb's Avatar
I just received my LS7 heads for my build. I was looking at a fairly aggressive cam. I"ve heard about some failures but, not the exact reason. What can I expect and what should I do to try to eliminate any possible issues? Or is it even anything to worry about. Is it something to do with the Ti intake valves?
Old 07-16-2007, 04:16 PM
gun5l1ng3r's Avatar
Hey Louis,
What/where are lashpads? And which bearings are you refering to? Are these very widespread problems or just freak occurance(although with how few Z06s there are, there shouldn't be any freak occurances...)?
Old 07-17-2007, 08:39 AM
SideStep's Avatar
Originally Posted by gun5l1ng3r
Hey Louis,
What/where are lashpads? And which bearings are you refering to? Are these very widespread problems or just freak occurance (although with how few Z06s there are, there shouldn't be any freak occurances...)?
I think Lou is referring to the steel caps (lashcaps???) that sit on top of the TI (intake) valve stems to protect them from the rocker... From what I have read this is not an issue on more mildly lifted cams... less than .615ish...
Old 07-17-2007, 03:24 PM
Haans249's Avatar
I'm running .646/.668 lift on my cam with no issues thus far. I did rebuild my rockers like I said just for extra insurance since I can't afford the R&D of running my cam on a valvetrain dynamics cell
Old 07-17-2007, 03:29 PM
Stang's Bane's Avatar
I have heard the same problem also. The lash caps wear, then the valve wears and then the valve drops
Old 07-17-2007, 03:59 PM
gun5l1ng3r's Avatar
Which bearings was he refering too?
Old 07-19-2007, 06:46 PM
RC45's Avatar
Hmmm.. so the valves are failing on stock heads with high lift cams? Is this fact or just rumour? And what are the lifts inducing these failures? Anyone run .700 lift?
Old 07-19-2007, 09:09 PM
GOaT Cheese's Avatar
What? I've never seen a lash cap wear to the point of causing a valve to drop. The lash caps are hardened steel,and the valve train noise would be rediculous before anything of the sort could happen.
Quick Reply: LS7s suffering valve-train failures from mild after-market cams???
