ABS delete codes. Here is the pin configuration
Old 11-22-2008, 03:00 PM
03 BUSA's Avatar
Default ABS delete codes. Here is the pin configuration
Did the search and found some of what I was looking for. However, there was no information on the TCS/ASR light. After looking thru the service manual I found what wires need to be grounded for all these lights to be turned off. This is all done at the connector on the ABS modulator in the engine compartment.
Pin 7 is for your ABS light
Pin 16 is for your Brake warning light
Pin 18 is for you TCS/ASR light.
These wires need to go to either pin 12 or 15 both are grounds. I recomend cutting these wires somewhere in the wire loom so it can be hidden and put back later if needed. Just connect the 3 above wires to either of the 2 grounds and solder and put back in the loom and all the lights should be gone. I feel this is better than the electrical tape method. This is out of the GM 98 service manual. Hope this helps.
Old 11-22-2008, 03:06 PM
wht01ws6ta's Avatar
Good information. They just go straight to ground, no resistor in between the pins and ground? Just a short straight to ground?
Old 11-22-2008, 03:08 PM
03 BUSA's Avatar
Correct. The ABS control module does that when everything is hooked up properly, you are just bypassing the module because you are taking it off the car so there is no way for it to ground the wires out to turn the light off. No resisitor. Straight up ground.
Old 11-22-2008, 04:55 PM
wht01ws6ta's Avatar
Ok thanks! This does sound like a good alternative way to do it rather than removing the bulb or taping over the light.
Old 11-22-2008, 06:14 PM
Moderator
jimmyblue's Avatar
What part of the service manual did you find this info in?
Would like to check out mine just to see if it's the same
across years etc. ('02, have the Helm set).
Old 11-22-2008, 06:49 PM
03 BUSA's Avatar
Factory GM service manual. Volume 2 the ABS/Brake system. You need to look at the diagram of the module pins. Let me know if this helps. I would really like to get this figured out for all years for everyone and maybe have a sticky made with the correct info for all years.
The following users liked this post:
TRANS2002 (03-09-2024)
Old 11-22-2008, 08:34 PM
2002_Z28_Six_Speed's Avatar
I might try it later tonight if I get bored.
Old 11-22-2008, 08:40 PM
03 BUSA's Avatar
Thanks
Old 11-23-2008, 09:14 AM
michaelg589's Avatar
wow definitely could be useful
Old 11-23-2008, 01:31 PM
03 BUSA's Avatar
I am in the middle of figuring out how to use your tcs switch to activate the line lock solenoid with a separate power switch. This would make it a very clean install as well.
Old 11-23-2008, 04:07 PM
Moderator
jimmyblue's Avatar
Looking at my manuals it says all the lights are Class 2 serial
bus and the data comes off the EBCM. Pin 18 on the EBCM
shows as a "Service Traction Control Indicator Control" and
is the ground feed for the TCS indicator lamp (not the dash
ASR OFF light, the LED in the switch). I see nothing for pins
7 or 16 on the EBCM in my schematic set. On the connector
pinout figure pins 7 and 16 say "Not Used".
I wonder what happens if you pull the ABS / TCS Class 2
serial data pin (25 on my '02 w/ NW9).
Is yours a 3-channel setup?
Old 11-23-2008, 05:53 PM
03 BUSA's Avatar
No 4 ch. In my manual it says.
Pin 7 is the ABS failure indicator Lamp output
Pin 16 is the Brake warning indicator Lamp feed-secondary
Pin 18 is the TCS indicator lamp output-failure
You need to cross refernce those descritions to your manual to see what the 99 up cars are. Those pins are normally ground when there are no faults. When a fault is detected it breaks the ground (how I am not real sure) and illuminates the lights. That is why cutting and soldering to one of the grounds keeps the lights off. I really appreciate the help on this. It has been too long that of an issue and would like to get this figured out for everyone no matter what year the car is.
Old 11-23-2008, 05:55 PM
03 BUSA's Avatar
Seems my pin 17 is real close to your descrition of pin 18. TCS switch signal??
Also, are you using a Gm service manual? Just trying to figure out if we are using the same terms or if they are 2 different published manuals which would use different desriptions.
Old 11-23-2008, 07:45 PM
Thorny's Avatar
I've searched and searched for this info with no luck. If someone could figure this out for the 99+ cars you might just make it into my will. I've tried grounding out each individual pin with no success. I've been let to believe that the lights were controlled by the BCM and could not be grounded out like the 98 cars could.
Old 11-23-2008, 07:58 PM
03 BUSA's Avatar
If the BCM controls this we need to figure out the wires on that end that need to go to ground. I wish I had the 99 up manual to look at. If anyone has a electronic copy of this it would also help to figure this out.
Old 11-23-2008, 10:17 PM
1BADAIR's Avatar
I have been searching for a way to do it too.
can't stand the Brake, Abs, and service vehicle lights being on
Old 11-23-2008, 10:41 PM
i am pretty sure you can't do this or everyone else would be able to. I really think i remember the last time I looked at the diagram that the lights were controlled via class 2 data.
Old 12-19-2008, 12:01 PM
greatskiiiier's Avatar
does this get rid of tcs and asr all together or jsut the light?
Old 12-23-2008, 11:38 PM
caviness's Avatar
i feel the same way wish somebody would figure it out for us
Old 12-24-2008, 12:20 AM
7 Second Club
NicD's Avatar
99+ I believe is serial data meaning you can't just do a simple ground wire mod like you can on the 98s. You need to open the cluster to disable them or put something over the light.
Quick Reply: ABS delete codes. Here is the pin configuration
