What weight oil for the boosted guys.??
Old 11-28-2008, 01:29 PM
charlie c5's Avatar
Default What weight oil for the boosted guys.??
What weight engine oil are you boosted guys running. This is a daily driver....
Thanks
Old 11-28-2008, 01:33 PM
GT67METHV's Avatar
mobil 1s 5w-30
Old 11-28-2008, 01:45 PM
charlie c5's Avatar
Cool thanks. Thats what Im running but due to an oil pressure issue Im having a friend of mine is telling me to change to a thicker oil. Like 20w-50.
Old 11-28-2008, 02:05 PM
Monello's Avatar
15w40 Rotella
Old 11-28-2008, 02:19 PM
GT67METHV's Avatar
yeah, i been following your thread with the oil pressure. thicker oil won't solve that low pressure issue. still no luck with said problem?
Old 11-28-2008, 02:22 PM
sevanseriesta's Avatar
if it helps I run 20-50
Old 11-28-2008, 02:34 PM
charlie c5's Avatar
Man, Im pulling my hair out here. I've had the front of the motor apart more times then I want to count. The little freeze plug style restrictor just behind the timing chain cover seems to be fine. I have the correct o-ring on the oil pump pick-up tube. I installed the restrictor in the oil supply line to the turbo hoping that would help, and I still have the same issue. I crank the car up cold and have great oil pressure, but as soon as the car warms up the pressure drops off the about 15 lbs at idle, and if Im driving and let off the throttle like to come to a stop the oil pressure drops off low enough to get the check guages light....
Old 11-28-2008, 03:12 PM
cablebandit's Avatar
15-40 rotella
Old 11-28-2008, 03:18 PM
maxgee's Avatar
I use to use Rotella on my bike and been using Mobil 1 in my car. Going to try Rotella in my Car.
As for your oil pressure issue, when I changed my heads and pulled the oil pressure sending unit out, it was going bad...put a new one and all is good...just FYI.
Old 11-28-2008, 03:26 PM
Blacklightning744's Avatar
do you have the LS6 Oil Pump Ported
Old 11-28-2008, 03:27 PM
SPRAYED 01's Avatar
I have not read your oil pressure thread so im not sure if this was mentioned. But,do you have a dual roller timing chain? If so you probably spaced out your oil pump. If so you could have installed the spacer on the driver side upside down. I did this when i put my turbo motor together and i had great pressure at cold start up,then it would go to like 20psi at idle and only 45psi at wot.
Just a thought
Alex
Old 11-28-2008, 08:01 PM
bboyferal's Avatar
M1 15w-50 has given me the best oil pressure under duress.
... Running a Mocal oil pump and an electric scavenger pump through my motor, my turbo, and an oil cooler.
With the **** beaten out of it good, it'll keep 40 psi at idle now.
I would freakin vaporize 5w-30, getting some really low oil pressure but not like the OP.
Old 11-28-2008, 08:07 PM
Turbo LS1 SS's Avatar
15-40 rotella..... although i may go synthetic if i decide not to put a cooler on it...
Old 11-28-2008, 08:17 PM
black98ws6ta's Avatar
Checked the oil/filter for metal yet? No weight oil is going to fix your problem.
Old 11-28-2008, 08:30 PM
bboyferal's Avatar
That's what this guy's problem sounds like.
Old 11-28-2008, 08:38 PM
red83's Avatar
Location: sneaking in your back door as you leave!/cartersville ga
rotella/delo
Old 11-28-2008, 11:12 PM
TS6
TS6's Avatar
You shouldn't have to run 20/50 to maintain good oil pressure, thats just a band aid. I run 10W40 and maintain 40 psi at idle when hot. I drive my car in cooler temps and having seen what 20W50 looks like at 30 degrees ambient I could never trust my motor to it. Its like hot vaseline. Unless I lived in an area with super high temps I'd never run 20W50.
Old 11-28-2008, 11:20 PM
bboyferal's Avatar
Welcome to Miami.
And there's no issue to bandaid... When I ran 15w-40 (Rotella), I'd keep good oil pressure too, about 35-38 after a beating... That's not bad. But with 15w-50, I keep 40 psi when really hot... I probably wouldn't use it in cold weather though, but I don't know what cold weather is.
Old 11-29-2008, 03:20 AM
charlie c5's Avatar
Yeah, I have the LS6 oil pump ported.
Old 11-29-2008, 04:11 AM
KissMySSo1's Avatar
valvoline VR1 SAE60
Quick Reply: What weight oil for the boosted guys.??
