Ls2/l92 help!
Ls2/l92 help!
I'm doing a L92 swap on a LS2. I have heard that bigger cams require cutting reliefs in the pistons to clear the valves. My cam is a 240/244 605/596 113+2 LSA. If i use a OEM thickness on the head gasket and don't mill the heads will the valves clear? Also, if they will clear, how much thinner can I go on head gaskets or how much can I mill the heads because I would really like a little compression bump.
its when you put clay on the piston and bolt the heads down and valvetrain and turn the motor over it will mash the clay down, if it stops you know it wont work if it turns all the way over tear it down and look at how thin the clay is, i believe thats what he meant by it, but im pretty sure someone could tell you without having to do all that work
