383 and maggie potential #s
how much power would a maggie and a 383 make. heads would be some 583 castings cncd, not sure about the cam, but it will be a blower cam, any #s u guys think it can make
The question is which maggie? The new TVS 1900 does not fall off on the top end like the 112 or 122. My torque curve on a 408 was basically flat, averaging 650ft/lbs on only 5lbs of boost. This engine made 727 peak hp at 6400 rpms with no drop off except we ran out of fuel and had to shut it down. The new blower makes a big difference.
i dont think i can put the 1900, i think the bolt pattern is different for the 1900
a kenne bell would be way better. if this is a street car i'd go with a Procharger or turbo setup, you will already have nice low end Tq from the stroker and it would be alot easier to hook up. And maggies are known to have heat soak problems and make your engine run hotter cause its bolted to the engine, so that could be an issue for you aswell.
with properly selected cam and heads, I get 655rwhp out of a 122, on an LS1
gobs of torque, at ALL RPM's
But, with the TVS's coming around, id go with one of them before a 112 or 122
with a 112 on a 383, expect somewhere between 550-600, depending on other factors
