Where to get a good MAP signal?
Where is everyone getting their MAP signal from for the hose barb style 2 & 3 bar MAP sensors? Can I T that signal and use it for other things like my wastecgate or is that not a good idea? If youve got pics I wouldnt mind seeing them.
I'd also like some pictures if you have any available. Are you putting the T visible on the brake booster hose or are you doing it closer to the rear of the intake?
You could get 99% out the material out. Its not going to be like metal shavings and be small flakes, plus the motor would consume the small plastic particle and **** them out without any problem.
For a safe, FI tune, I like the tube to go to the MAP only, and be a thickwall tube, ziptied at both ends, and be as short as possible. I'd tap and do the seperate hose thing.
Jim
Jim
