when on jack stands one side sits lower(rear)
Old 12-27-2008, 04:20 PM
blake110106's Avatar
Default when on jack stands one side sits lower(rear)
I noticed this last night when trying to figure out my problem with the rear end. Its not centered(about 1/2 inch to driver side) I havent found anything that would cause this but I found out that the pass side sits 3/4 inch lower than the drivers side when the rear suspension drops all the way. I've checked the shocks and they are fine.
Anybody had any similar problem? Any idea on what it might be?
Old 12-27-2008, 04:36 PM
99Bluz28's Avatar
Question
Do the rear upper shock bushings both look tightened the same, is the passenger side upper mount nut loose?
Old 12-27-2008, 06:45 PM
I'll be checking tomorrow. I had to stop working on my car and hook my brothers GF car. I'll let you know!
Old 12-27-2008, 06:54 PM
HavATampa's Avatar
It's centered when the weight is on the wheels though? I believe the way the PHB angles are that when the rearend is lowered all the way, it's normal. Why does it even matter as long it's straight when sitting on the ground? I can't drop mine all the way due to my exhaust.
Old 12-27-2008, 08:40 PM
no its not centered when on the ground. if it was i wouldnt even worry about anything
Old 12-27-2008, 08:48 PM
HavATampa's Avatar
You need an adjustable PHB then to center it. If the car sits lower on one side in the back, it may be as simple as rotating one of the coil springs in the pocket to even it out. If that doesn't help, it could be a weak spring.
Old 12-27-2008, 09:35 PM
ill check the springs as well tomorrow. I've been debating on ordering rear suspension stuff for about a week. I guess now I can
Old 12-28-2008, 08:35 AM
Manic Mechanic's Avatar
Check for level on the ground, if you have a weak spring the opposing corner will be opposite. On mine the right front spring was sagging and the RF fender hieght was lower than the LF. This caused the LR of the car to sit higher than the RR. The whole car was leaning over towards the weak spring.
What you're checking with the suspension at full droop is shock length and the arc of the panhard bar. Neither of which is very important unless you find a busted shock mount or bushings as stated.
Vernon
Quick Reply: when on jack stands one side sits lower(rear)
