Installed Torque Arm But Feels The Same
Old 12-29-2008, 03:38 PM
jattgunman's Avatar
Default Installed Torque Arm But Feels The Same
I just installed a adjustable torque arm in my 2001 SS M6, And I really cant feel to much of a difference versus stock..the Torque Arm is at 0 and the drive shaft is at -2 which should result a pinion angle of -2?
Old 12-29-2008, 04:15 PM
Elliott's94Z's Avatar
What were you expecting to feel?
Old 12-29-2008, 04:27 PM
OIF1VET's Avatar
Did you change from a long to a chassis mount? If not you really won't feel anything diff.. When I swapped I went from tranny mount to Chassis mount and the diff was night and day for me...
Old 12-29-2008, 04:29 PM
LS1Tech Premium Sponsor
BMR Tech2's Avatar
The pinion angle should be -2 degrees. The purpose of upgrading your torque arm is strength. The stock arm is made from stamped steel is is a very weak product. Under a heavy load it will bend and flex. Aftermarket torque arms will not. Combined with other suspension parts you will see a performance gain in you car and your suspension will be more reliable. If you have any questions about how to set your pinion angle refer to our video or just give me a call.
http://www.bmrtvonline.com/video_detail.php?mId=3788
http://www.bmrfabrication.com/
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old 12-30-2008, 06:41 AM
leadfoot4's Avatar
I hope you mean the driveshaft is at "0", and the rear axle is at "-2"....
Old 12-30-2008, 09:17 AM
SuperSlow02's Avatar
chassis mount will make more noise...at the track is where you'll feel the difference
Old 12-30-2008, 10:31 AM
Big Bird WS6's Avatar
^^^^ not true
Old 12-30-2008, 12:05 PM
OIF1VET's Avatar
I don't have any real noise issues.. A little clunk now and then, nothing major to me..
Old 12-30-2008, 01:53 PM
jmilz28's Avatar
The rear end of mine felt tighter after the install, if that makes sense. It also helped me find the traction limits of the tires more easily.
Old 12-30-2008, 04:32 PM
Originally Posted by Big Bird WS6
^^^^ not true
glad youve driven my car
Old 12-30-2008, 04:33 PM
trust me, its not an issue, just an observation.
Old 12-30-2008, 05:02 PM
jattgunman's Avatar
Yea it was wrong when I installed it..for some reason I think I added instead of subtracted...But its a -2 now for sure...I think(+1ta and +3ds)
Last edited by jattgunman; 12-30-2008 at 09:57 PM. Reason: positives not negatives
Old 12-30-2008, 06:18 PM
2001z's Avatar
Like everyone else has said you will feel it more when you launch the car with something sticky it wont flex/bend/break like the stock POS and should give you better weight transfer. I just bought the chasis mount for the shorter tq arm.I purchsed one after seeing some tailshafts destroyed from the stocker breaking.
Old 12-30-2008, 09:58 PM
jattgunman's Avatar
i have noticed it to take off a lil better..but the true test will be at the track
Old 01-01-2009, 05:05 PM
well maybe you should buy i good one. i was saying that the noise isnt true. i have been in alot of cars. with chasis mount and no niose.
Old 01-01-2009, 05:29 PM
weird I forgot the UMI Chassis mount was garbage. The noise is true, and most of the manufactures will tell you that you MIGHT pick up road noise but its not enough to matter to the majority of us, which would be me. For one your taking the torque arm out of a rubber mount and bolting it directly to the body of the car....If you dont think that will trasmit more noise then I dont know what to tell you. This isnt the point of this post, the only reason why I said it was because it was the only difference I could tell in the change on the street, It was ment more as a joke to the OP then anything.
Old 01-02-2009, 03:59 PM
shaun's Avatar
it will help mostly at the track when trying to get a good launch.
i have a stock converter,aj ta,lca's and so only thing is stock is the phb and i can pull 1.8 some times a 1.7 60ft on nitto drags.
Old 01-05-2009, 12:01 PM
great421's Avatar
Set the adjustable torque arm to an angle of -3.5 and thank me later!
Quick Reply: Installed Torque Arm But Feels The Same
