LCA Question
Old 12-30-2008, 12:59 PM
SheaMus's Avatar
Default LCA Question
I just recieved my BMR poly/poly adjustable Street LCA's for my car. What would be better for my Daily Driver. Do poly adjustables run into binding issues? People are saying poly/rod? I want to know before i install these on my car. Thanks.
Old 12-30-2008, 01:09 PM
LS1Tech Premium Sponsor
BMR Tech2's Avatar
Hello, the poly/rod arms will articulate better than a poly/poly but for a daily driver the poly/poly is a great choice. If you decide that you want the poly/rod combo give me a call.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old 12-30-2008, 02:31 PM
01CaMMMaro's Avatar
for a DD you should go poly/poly as noted above, rod ends wear out alot faster than poly ends... especially on a DD.
Old 12-30-2008, 02:51 PM
BMR Tech2's Avatar
Keep the poly/poly greased good and you will not have any issues. Make sure you use a synthetic based grease.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Old 12-30-2008, 03:03 PM
Big Bird WS6's Avatar
^^^ a synthetic grease that is for marian(water) is better. then it helps repel water
Old 12-30-2008, 07:06 PM
SheaMus's Avatar
thanks for the info guys
Old 12-30-2008, 11:29 PM
SheaMus's Avatar
where can i pick up this silicone based polyurathane grease at? I have a grease gun
Old 12-31-2008, 08:38 AM
advanced. lol ^ ^ ^ ^ got mine there.
Old 12-31-2008, 09:09 AM
toadzq8's Avatar
Ask Dennis at BMR about the softer rubber bushings unstead of the poly bushings but just on one end of the LCA. I have them in my BMR adjustable street LCA's and like the results, no hop and the softer bushing allows it to twist just a bit so it don't bind and has less noise!
Old 12-31-2008, 09:28 AM
02SS0384's Avatar
I'm running BMR Poly/Rubber also. I'm happy with them, no noise at all!
Old 12-31-2008, 09:29 AM
BMR Tech's Avatar
Glad to hear you like the rubber bushings not many people have tried them but those that do love them....
This option is available for all of our lower control arm and panhard rods.
Old 12-31-2008, 10:10 AM
BMR Tech2's Avatar
Like toadzq8 said if you would like that option we do offer it and have for quite sometime. Just give us a call and mention that you would like the rubber bushings instead of urethane we will make the change for you.
HAVE A SAFE AND HAPPY NEW YEAR!!!!
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Old 01-01-2009, 12:19 PM
i am running a poly poly rod end set up and it is great.
Quick Reply: LCA Question
