Help me hit 400 wheel cam recommendations?
Old 01-15-2009, 09:27 AM
Nissankat's Avatar
Default Help me hit 400 wheel cam recommendations?
Ok so I知 new to the ls1 scene (coming from turbo 4 bangers) but I have been creeping around this site and learning a ton. I am swapping an ls1 from an 04 gto into my 240sx and would like to hit 400 wheel on the initial install. The car is a 2800 pound auto-x/lapping day car that sees very little street use. With the install it will be getting long tube headers and an exhaust and also a good tune. It will also get a fidanza AL flywheel and probably a spec stage 3 clutch. Also the current rear end gearing is 3.91 if that matters.
My question is what other mods will be required to meet my goal? I知 sure a cam and maybe heads. Any recommendation on either of those would be great. I知 not limiting my self to 400 wheel that is just the initial goal. Thanks
Old 01-15-2009, 09:31 AM
teke184's Avatar
any of the low 23x cams should get you there with stock heads.
if you want something with a little smoother idle and possibly more low end, i would say go for a smaller cam and some small runner heads.
something like the TR 228 cam with a set of milled AFR 205s would probably get you about 430rwhp (fbody drivetrain) and great low end power.
cam only i would say go for something like the TSP torquer 2, or the FMS F14
Old 01-15-2009, 09:33 AM
Restricted User
transammiller's Avatar
stock 241s with Comp 918s, Comp 228/230, pacesetter LTs, LS6 intake, and ported TB got me 434 wheel hp before the tune. and it was my daily driver. 400 hp is easy with a stock longblock LS1. you shouldn't have any problems. if you go HCI with LTs and a good tune 450+ will be VERY easy.
Old 01-15-2009, 09:36 AM
SuperSport01's Avatar
A magic stick 3 or 4 would do that and more.
Old 01-15-2009, 09:37 AM
conan's Avatar
What "teke" said. I had a 224 cam in my last setup and made just under 400rwhp. A 23x duration and 59x lift will get you to the 400hp mark, and throw a set of heads in there... you'll have your goal for sure. 2,800 # car and 400+ at the wheels will be fun.
Old 01-15-2009, 12:57 PM
teke184's Avatar
are you sure??
that's WAY high for a mild cam like that and untouched heads.
especially with no tune.
Old 01-15-2009, 03:54 PM
Nissankat's Avatar
Ok so you guys have given me a lot of cam suggestions that I will look into. It will still be difficult to come to a final decision on that though. I don’t think I can come up with the money for some really nice heads just yet so would a set of stock ls6 heads be a good option? With some better valve springs of course. My main concern is good low end and a nice usable power band.
Old 01-15-2009, 05:34 PM
teke184's Avatar
stock ls6 heads are a nice upgrade, but for the expense of the swap...you'd be better off spending a little $$ and getting them touched up.
figure stock the heads will give you about 15-20hp over stock ls1 heads...depending on the cam
Old 01-15-2009, 05:58 PM
LS1-NAVY's Avatar
pm pat g and get a custom cam
Old 01-15-2009, 06:06 PM
02BLKWS6MD's Avatar
Patrick G and Predator-z could spec a cam for you to make some good power. Predator-z speced out a 230/230 cam for Chris1313 and he made 422rwhp through an A4 trans. Alot of your power is gonna come from the tune, if you get a good tuner.
Old 01-15-2009, 06:46 PM
SOMbitch's Avatar
Originally Posted by teke184
are you sure??
Agree with you teke....musta been a happy dyno
You can learn a lot from this site but gotta have a good BS filter
Old 01-16-2009, 08:17 AM
teke184's Avatar
yeah there's always that guy that chimes in with 400-410rwhp on a 224 cam only, through an auto with a 12bolt....while the rest of the world has a hard time hitting 410rwhp with a 230 cam, an m6 and a 10bolt
Old 01-18-2009, 06:25 PM
Nissankat's Avatar
Ok so I think Im going to go just cam for now. Im thinking I will take Tekes advice and go with the TSP torquer 2. What Lsa do I need. Im not sure what that is.
Old 01-18-2009, 06:54 PM
Adam1982's Avatar
https://ls1tech.com/forums/advanced-...ect-power.html
Cam sticky at the top of this section, you should read it.
Old 01-18-2009, 10:20 PM
01ssreda4's Avatar
very true, that dyno lied to him....
Old 01-18-2009, 10:38 PM
WS6ICK2k's Avatar
+ 1
