WOT not shifting/backfiring
Old 01-16-2009, 08:35 PM
00Antivenom's Avatar
Default WOT not shifting/backfiring
My car is in my sig, 3'' piping with no muffler, so backfire is really obvious. Lately, when I go WOT, when it gets to the high RPMS, it doesn't shift. It just backfires constantly. Anyone else had this problem? I'm going with LTs and TDs at the end of the month, hoping the tune will help. A4 btw.
Old 01-17-2009, 12:05 AM
Anyone?
Old 01-17-2009, 10:13 AM
ttt...
Old 01-17-2009, 10:15 AM
the_merv's Avatar
Tune it and adjust the Shift Points and Line Pressures.
Old 01-18-2009, 09:16 AM
sixvi6-camaro's Avatar
Sounds like the Trans is slipping and you are bouncing off the rev limiter. A tune or adding more power won't help a trans on the way out.
Old 01-18-2009, 10:23 AM
Really? That sucks. Like...bad. Do you suggest I go to an m6 if that's the case?
Old 01-18-2009, 11:02 AM
99_Z28's Avatar
Its blowing threw the shift points and hitting the limiter. Get someone set the shift point at 5900 and the limiter set at 6300. Change the tranny fluid and filter while your at it.
Old 01-18-2009, 11:21 AM
Can that be done with a tune?
Old 01-18-2009, 12:54 PM
99_Z28's Avatar
Yes it has to be done with a tune. Thats just a band aid for the slipping tranny to give it more time to shift before it hits the limiter.
Old 01-18-2009, 01:08 PM
I'll remember to put that in my order form when I ship my PCM to LSxTune.com
