SLP Header fit!
SLP Header fit!
Im in the middle of installing my slp lts and im on the passenger side. ive jacked the car up very high and took the starter out when i go to slide it in i get 2 of the primaries in and the flange on the last primary hits in the trans tunel . any help greatly appreciated!
Took the starter off? It shouldn't be giving you that much trouble. Try lifting the car a little higher man and try a different angle. The passenger side was a lot easier than the drivers side for me.
Ive unbolted the starter it is hitting the trans tunnel on the end of the last flange when i unbolt the trans mount how will it give me more room cause the motor mount is still holding it
I dont have access to a camera it is the spot right where the bellhousing is I have the car up high enough to turn the headers straight up but it seems whenever i think it is gonna go in it hits that spot and wont go any farther!
I havent loosened the motor mounts yet i have quit for the day the header catches on the end of the k member across from where the starter is and the trans tunnel right above it I would really not like to cut my k member it seems that it just doesnt want to go in!
this was the only issue i ran into when installing my SLP's,,,i used the ol BFH mod on the spot where the hearder would hit,,,didnt take much to change the shape of that area to let the header squeek by...i mean like 3 or 4 hits did it. I did mine this way without messing with the starter. As mentioned, you do have to unbolt the trans mount, stick a 2x4 or whatever up there, and give a lil shove over towards the drivers side. I would do the grinding on the K member LAST, (you probably wont have to do it) I did not do anything with the motor mounts on mine...Hope everything goes well!
Also hope you rerouted the pass side wires like you have to so it doesnt burn through the harness. oh well, **** it!
You don't need to grind, just loosen up some bolts, get a ratchet strap, your favorite hammer, and go to town with it. As Mike said above "CHECK ALL THE WIRES" or you will only be able to drive 1.2 miles before the positive wire to the starter welds itself to the header. Yes I know from experience, I should've double checked the wires, I had to rerun the start wire.
