Help me pick head/cam combo
Hey everyone once again another post asking about head and cam combos LOL. My buddy has a 01 ls1 a4 with stock gears. He has 2k to get everything he needs for this except the stall which he will have to save for. The stall will most likely be a 3800-4000, he wants a nice idle with some good hp but most importantly good low and mid range. He is going to stay with the ls6 intake and going with all the good acc like the ls7 lifters and ported pump. I was thinking about TSP's stage 2.5 5.3 heads with a torquer 3, what you'll think about that? Thanks
LS1Tech Premium Sponsor
The 5.3l head & Torquer 3 combo will work really well for him! Tell him to checkout the sponsor section, we're posting specials today!!!
http://www.texas-speed.com/shop/item...d=203&catid=47
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
Stock gears? Does he have GU5 with 3.23s or does he have the 2.73s? May want to get some bigger gears if so. I think the setup you picked out would be great for what he's looking for. I am about to put in my G5X3 with some 243s, went the big-ish cam route.
This is what I would suggest and currently bulding.
http://www.neweraperformanceparts.co...=NEPSShtCamF|0
Cam http://www.youtube.com/watch?v=N7nYRekEoiA
http://www.neweraperformanceparts.co...A=E&PKV=2013|0
Heads
http://www.neweraperformanceparts.co...&PKV=ytls1rr|0
Rocker arms
http://www.neweraperformanceparts.co...E&PKV=100221|0
Balancer
http://www.neweraperformanceparts.co...lanteTripleF|0
4000 converter
http://www.neweraperformanceparts.co...KV=LS19899-1|0
Headers
http://www.neweraperformanceparts.co...PKV=flmt30cf|0
Injectors
Heads
Rocker arms
Balancer
4000 converter
Headers
Injectors
you guys miss the part about a 2k budget?
5.3 2.5s
T V.3
ls6 intake
3600-3800 stall
that setup will SCREAM in the low-mid range..
a buddy of mine has an f13, 5.3 2.5s, 373s, 3500 stall, full bolt ons, ls6 intake 28 inch tire.. in the 1/8 mile... i kill him out of the whole by about 2 lengths... then he comes back real quick after the 60 up about with his nose at my door, and holds till the end of the 1/8 mile.. i out trap him by about 1/2 MPH..
that was when i had ms4 cam, ported 9090, 410s, 4k stall, 26 inch tire, full exhaust, stock everything else.. was not tuned for gears or intake..
i would beat him every time by 2 tenths from a dig... he would beat me from a 40 roll by about 1/2 a car every time cause of his mid range and throttle response..
i would go for that setup if he wants a smaller cam..
5.3 2.5s
T V.3
ls6 intake
3600-3800 stall
some vids of said setup..
the f13/5.3 setup is the red camaro..
motor
http://s250.photobucket.com/albums/g...t=SD531021.flv
he sprayed on this one..
http://s250.photobucket.com/albums/g...t=SD531024.flv
he sprayed on this one also.. and yes i had a headlight out..
http://s250.photobucket.com/albums/g...t=SD531028.flv
motor
i would talk to louis at LG motorsports. a g5x3 could give some power. as far as heads go, you might be able to find a set of inexpesive used afr's or darts or what not on ls1tech. just keep an eye out and look, but the tsp heads could also bring some good power.
