DIY Turbo Gurus Come in and Help Out With a Turbo Build Idea
I have always ran N/A but the big numbers that ya'll are making with the truck manifolds and front mount turbos really has my interest in doing one myself. If my idea is just totally screwed up and want work please just tell me so. I was thinking why not build a front center mount turbo car coming off the pace setter headers that I currently have with some 2 1/4 or 2 1/2 tubing in the shape of a "U" to get the hot piping headed back to the center front and then tie that into a Flow Master merge that would then have a single pipe going into the turbo??? The new "Y" pipe with merge would run under the factor cross member that could be notched if necessary for clearance or run a BMR cross member still running the piping under the cross member unless room was plentifull between the BMR member and motor?
I was thinking this way the AC could be kept and no need to move the alternator either.
Please let me know if this is possible or if it has been done with success and any comments or suggestions would be greatly appreciated.
Great. I didnt know if it was alright to merge both pipes coming off the headers and only run one pipe into the turbo instead of the two mateing up at the turbo. If it is alright to run just one pipe out of the merge into the turbo what size pipe should it be? Also, any suggestions to what turbo to use?
I also wondered if you could use the truck manifold on the driver side and use the stock f-body exhaust to the rear on the passenger side and route that tube back up front to meet up with the turbo and the other hot pipe, thus making it possible to keep the AC. I just didnt know if the hot pipes had to be pretty much the same lenght or not? With this set up the passenger side hot pipe would be much longer than the driver side.
Thanks in advance for the help.
Where are you putting you radiator and intercooler with this front and centre mounted turbo??
Sure with a car only running 8 seconds at a time, you could get away with meth and a A2W but street car?
Just sell the pacesetters and buy some truck manifolds. I think you would run out of room trying to pipe the up-pipe back to the front of the car. Also it would have lag issue like an sts kit because of how long the hotside would be.
you should consider selling the headers and put stock manifolds on it, then you have more room and you dont have to make a whole 180 turn under the car. guys are making a lot of power on truck manifolds so i dont think the flow is that big an issue( unless your going all out). mine is built with 2 stock passenger manifolds. ive seen the use of a corvette manifold with the pipe tucking between the a arms too.
By front and center I just ment that it would be setting in front of the water pump like alot of them do and the radiator would be changed to a Griffin so it could be set straight up to get the necessary clearance.
you should consider celling the headers and put stock manifolds on it, then you have more room and you dont have to make a whole 180 turn under the car. guys are making a lot of power on truck manifolds so i dont think the flow is that big an issue( unless your going all out). mine is built with 2 stock passenger manifolds. ive seen the use of a corvette manifold with the pipe tucking between the a arms too.
Thanks for your help
One passenger side 6L truck manifold turned around and installed on the driver side. One passenger C6 manifold installed in stock configuration on passenger side.
Read and dream:
https://ls1tech.com/forums/forced-in...old-setup.html
Read and dream:
I don't mind using the truck manifolds except what I've read is that you loose your AC. You mentioned using 2 stock passenger manifolds, by doing this are you able to keep your AC and how are the pipes routed? If you have any pictures it would be greatly appreciated.
you could do the pipes the same way, have a front mount, relocate the alt and keep ac.
Read and dream:
Read and dream:
Read and dream:
Read and dream:
it is not needed with truck manifolds
