224/110 cam is in and running...
Old 10-08-2003, 12:06 PM
*Bad Trader*
BYBYC5's Avatar
Default 224/110 cam is in and running...
WOW, this thing is a TQ monster all the way to 6k and still pulling, havnt taken it past 6k yet, still breaking her in and seating the rings, idles like a prostock car, its hard to tune for throttle return but hopefully that will be fix with a little dyno tuning, its fast reving, power everywhere and i just love this cam. all tho id have to say its not for an A4 car unles you can stand the idle issues, ( i have an A4 with a 3600stall) but in a M6 it would rule on the street. mods as of now are
ported 5.3 heads milled .015 2.00/1.56 stainles valves
stock bottom end
224/.570 110lsa 106icl
tuning by raging motorsports(good job guys)
ls6 intake(2001)
long tubes/ true duals w/borla xr1s (going back to hooker catback soon)
3.73s and a MW3600 2.37
lots of other little stuff
hopefully i can have a sound clip soon if someone can host it...
Old 10-08-2003, 12:11 PM
Z-Rated's Avatar
Default Re: 224/110 cam is in and running...
ohh a 110 in an auto I bet that thing sounds sick. we gotta hear it, and when you do let it idle for a while, not this 10 seconds then revving it. for a sound clip revving it sounds horrible....
What were the dyno numbers and do you have a graph? I want to see the power curve
Old 10-08-2003, 12:17 PM
D(irecto)r Pepper
Raughammer's Avatar
Man, tuning sure has come a long way, that thing must hit HARD.
Keep us informed!
Old 10-08-2003, 12:21 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Did you pay Pekka H. back yet?
Never mind I gave you a new title.
Good luck with the car the cam sounds fun.
Old 10-08-2003, 12:25 PM
CHRISPY's Avatar
what were your dyno numbers after tuning? Where did you peak? I bet it peaks pretty low with 110LSA and 4 degrees advance...
Old 10-08-2003, 06:31 PM
Trojan T/A's Avatar
Lets hear a clip and see some dyno results. Are you still having drivability with the cam after the tune? I was looking to go 110lsa with a tune but if still a problem in an A4 I will pass.
Old 10-08-2003, 09:36 PM
blkZ28spt's Avatar
I'm in that boat too. SOUND CLIP PLEASE! Nice, long idle. I REALLY want lope and am considering a 110 LSA in stock converter A4 if it is possible.....
Old 10-09-2003, 12:14 AM
*Bad Trader*
BYBYC5's Avatar
it peaks around 62-6300
ill post a graph as soon as i get it dyno tuned.
i have the vid just gotta find someone that can put it on a computer but ill def. get it up and posted.the drivability is great like i said the only problem now is the idle/throttle return. i dont know about the stock converter, i think my stall is accually helping the idle a bit, id recomend this cam to any M6 but only the hard core A4 folks who arent afraid to tune and have a thumpin' idle, my radio is almost usless now (dont know if thats a good thing,lol)
Old 10-13-2003, 09:34 AM
*Bad Trader*
BYBYC5's Avatar
having a slight problem with tuning this thing, it runs fine but start ups and coming to a stop ,no matter what i try i cant get it to stay running without a little foot help..any ideas, raise the idle or somthing eles, someone mentioned the throttle return tables but i have no idea or ls1 edit even if i did....just want a little advise for when i have it tuned again....
Old 10-13-2003, 06:30 PM
GrannySShifting's Avatar
I bet it peaks at 6000, maybe with the heads a bit later, 6200 max. Guy round here peaks at 5900-6000 with that cam
Old 10-13-2003, 06:56 PM
v8maro's Avatar
you should be able to drill the tb hole in 1/64 increments to increase air in.
-Steve
Old 10-13-2003, 09:41 PM
*Bad Trader*
BYBYC5's Avatar
na it goes all the way to 62 an some change, im pretty sure the lobes are diffrent but anyhow, i like the cam
my TB is allready drilled quite a bit, kinda reluctant to go higher.
