ls6 intake on stroker?
Old 02-12-2009, 08:51 PM
ozzman98's Avatar
Default ls6 intake on stroker?
Hey i was just wondering if anyone on here knew how an ls6 intake would perform on a 408 stroker making a little over 500whp? i know its not the best intake for that application but i was wondering bc i need the car to appear as stock as possible and im also on a budget. thanks.
Old 02-12-2009, 08:52 PM
Ericbigmac83's Avatar
doubt it will make 500+ with that intake and with budget heads
Old 02-12-2009, 08:56 PM
JonCR96Z's Avatar
I'm not sure how well a 408 with an MS3 is gonna pull off the stockness that you're going for.
It will perform fine. I'm sure there are lots out there with similar combos. It would just perform better with a better intake
Old 02-12-2009, 09:12 PM
LS1-NAVY's Avatar
a ported ls2 intake is like 7 hp less than a unported fast
Old 02-12-2009, 09:14 PM
LS1-NAVY's Avatar
https://ls1tech.com/forums/generatio...-manifold.html
this might help you
Old 02-12-2009, 10:34 PM
Mean87SS's Avatar
OK... he has a LS6, not a LS2
Old 02-12-2009, 10:42 PM
JonCR96Z's Avatar
He's saying buy a ported LS2 intake. It looks kinda stock and isn't as much as a FAST.
Old 02-12-2009, 11:14 PM
ozzman98's Avatar
okay thanks guys a appreciate it, i saw a comment out there about budget heads, the car is actually my buddies t/a, he has patriot stage 2 ls6 heads, 2.02/1.57 and flow 296 at 600 lift, already owns the ls6 intake and wants to know if that will be sufficiant enough or if the motor is plain just gonna run bad. thanks
