Ported TB, now high idle.
FYI, you're probably seeing 50% or less of the porting gains doing it with a dremel. There's no possible way you can properly blend, smooth, and remove the right amount of material with one. I've tried several times before and it's not possible, compared to using the correct tools. You might want to send yours off to be finished, and have the blade replaced at the same time.
Thanks!
Sounds like the throttle blade is not centered or the blade is closing too much and binding on the housing. Center the blade on the housing by loosening the blade bolts and allowing the blade to sit freely while closed. Tighten the bolts in place. Then ensure the blade is not sticking as you crack it open, you will need to adjust the idel set screw to hold the blade just a hair open, just prior to sticking. If you need help, just bring it by.
