i need traction
i need traction
i finally took the car to the track this weekend and was having a terrible time with traction, off the line and when it hits second, im running a 255 50 16 falken with about 35 psi, what kind of pressure should i run at the track and should i heat up the tires or run them "cold"
okay then, will do hopefully someone has a set on here, any idea on which is the best ive heard nittos arent worth calling a drag radial, and that bfgs may not hook up, but my car is mostly stock so.....
