Fueling & Injection - who DD with a fuel regulator mounted at the rails?
RooRnZ28
02-20-2009, 03:40 PM
like the title says, just wanting to know who DD with their front mounted fuel regulator and aftermarket rails... i keep reading about "heating the fuel" and such when running one at the rails, but don't know if this is a bad thing or not?
I am in the process of adding a new feed line with a new fuel regulator and using the stock feed line as the return, but I want to know if I will have problems with "heating the fuel" and returning it to the tank.. I dont drive the car EVERY day, but don't want any problems if I chose to do so!
any help or insight is greatly appreciated!
ElectronSS
02-20-2009, 03:46 PM
3k miles with mine on rails and no issues. mine is on the back of driverside rail and its feed from passengerside. return is off the regulator
MeentSS02
02-20-2009, 04:05 PM
I don't daily drive mine, but it has never given me an issue having the regulator up front - I did notice that the car smells a little more now of gas (I'm assuming from the increased evaporative emissions since the fuel is being heated and then sent back to the tank), but the fuel pressure stability was well worth it.
RooRnZ28
02-20-2009, 05:24 PM
That makes sense, more evaporative emissions (moisture) in the tank due to the heated fuel circulation.... would this be detrimental to anything over extended periods of time, like could the gas get diluted?
i assume that you guys aren't running EVAP either? I still have mine... so i wonder if that would help anything or not
MeentSS02
02-20-2009, 06:35 PM
Not sure - I don't think it'd be bad in the long run. From what I understand, manufacturers don't run the return from the rails anymore to keep the evaporative emissions down, and that's really the only good side of it (mine dropped fuel pressure like a mofo with the return in the back like it is).
And you are correct in your assumption - I actually use the EVAP hard line for the return, and I have the tank vented on the top of the tank.
Packy
02-21-2009, 10:23 AM
I have mine on the rails. No worries with it but my car is a weekend/track duty only cruiser.
Lonnies Performance
02-21-2009, 08:32 PM
The only time you run into problems is if you run a huge race pump on the street & circulate too much fuel. An intank pump will never have any problems.
RooRnZ28
02-22-2009, 03:39 PM
thanks for the replies guys... a little more emissions won't hurt anything :angel:
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
