newbie questions, sbc to ls conversion in my Ultima
Hi All
I currently have a EFI 377 cuin sbc fitted to my Ultima GTR but i want to upgrade to a LS2 or 3?? I also want to run a Procharger with a relatively stock motor. So if you dont mind i would like to ask some questions.
1 would it be better to run a Gm ECU or an aftermarket unit??
2 wet or dry oil pan?? i hope to do some trackdays
3 is it easy to spin the inlet manifold as its necessary in the Ultima as its mid engine
4 is the LS2 as strong as the 3?? its quite a bit cheaper
5 would you go for a crate motor or a pullout?? i think it really depends on how much of the standard bits i can use.
thanks for your time, we in the UK and Europe are long way behind you guys in reference to the LS
kyle
kyle
Hi All
kyle
kyle
1. Without a doubt, GM. Get HPTuners or EFI Live and you will have better functionality than most stand alones.
2. Unless you really expect sustained high-gloads there is no need for a dry sump.
3. The intake manifold can be installed either way with no trouble.
4. IMHO it doesn't matter, if you are going to do a cam change, head swap or any other work to the engine they are basically the same thing (except with respect to displacement, but if you are going forced induction that doesn't really matter given the small difference in displacement).
5. I would get a pullout and make sure it has the front accessories that will fit your application. If you have money to burn then a crate motor is nice or for less money you can buy a short block and the parts you need.
Sounds like fun .
www.hptuners.com and www.efilive.com both will require research and some studing to make full use of the programs. the ecm section on here is a good place to start.
