newbie questions, sbc to ls conversion in my Ultima
Old 02-21-2009, 03:03 PM
ultimaboy's Avatar
Default newbie questions, sbc to ls conversion in my Ultima
Hi All
I currently have a EFI 377 cuin sbc fitted to my Ultima GTR but i want to upgrade to a LS2 or 3?? I also want to run a Procharger with a relatively stock motor. So if you dont mind i would like to ask some questions.
1 would it be better to run a Gm ECU or an aftermarket unit??
2 wet or dry oil pan?? i hope to do some trackdays
3 is it easy to spin the inlet manifold as its necessary in the Ultima as its mid engine
4 is the LS2 as strong as the 3?? its quite a bit cheaper
5 would you go for a crate motor or a pullout?? i think it really depends on how much of the standard bits i can use.
thanks for your time, we in the UK and Europe are long way behind you guys in reference to the LS
kyle
Old 02-21-2009, 03:13 PM
1_bad_TA's Avatar
Why not run the procharger on the 377?
Old 02-21-2009, 03:40 PM
ultimaboy's Avatar
11.0 to 1 compression ratio and old technology i can also run the Procharger off boost to give decent LS economy.
Old 02-21-2009, 05:54 PM
rao
rao's Avatar
Originally Posted by ultimaboy
Hi All
kyle
I'll give it a go...
1. Without a doubt, GM. Get HPTuners or EFI Live and you will have better functionality than most stand alones.
2. Unless you really expect sustained high-gloads there is no need for a dry sump.
3. The intake manifold can be installed either way with no trouble.
4. IMHO it doesn't matter, if you are going to do a cam change, head swap or any other work to the engine they are basically the same thing (except with respect to displacement, but if you are going forced induction that doesn't really matter given the small difference in displacement).
5. I would get a pullout and make sure it has the front accessories that will fit your application. If you have money to burn then a crate motor is nice or for less money you can buy a short block and the parts you need.
Sounds like fun .
Old 02-22-2009, 03:16 AM
ultimaboy's Avatar
thanks Rob
i cant wait to get started, is the Gm ECU easily programmable??
Old 02-22-2009, 06:00 AM
rao
rao's Avatar
It is, the software it very powerful and pretty easy to use.
There are forums for both HP Tuners and EFI live and there is a forum here dealing with tuning issues.
Old 02-22-2009, 06:26 AM
ultimaboy's Avatar
ok thanks again
where can you get the software from??
Old 02-22-2009, 07:54 AM
dogger's Avatar
www.hptuners.com and www.efilive.com both will require research and some studing to make full use of the programs. the ecm section on here is a good place to start.
Quick Reply: newbie questions, sbc to ls conversion in my Ultima
