Lap top computer stand for our cars?
Old 10-14-2003, 02:37 PM
Tom the roofer's Avatar
Default Lap top computer stand for our cars?
I am looking for a lap top computer stand that bolts or welds to the tranny tunnel. Or where ever they mount to. Any of our sponsers carry these? Know where I can find one? Links?
I want to secure my lap top for A-tap diagnostics.
TIA
Tom
Old 10-14-2003, 02:43 PM
Fast SS on TNT's Avatar
Default Re: Lap top computer stand for our cars?
Afterthoughts Automotive has one. Check the sponsor list.
You can also search around with Google for police cruiser equipment. They are alot cheaper from other websites.
Laptop Mount Pic
Old 10-14-2003, 02:50 PM
Thanks Fast SS
Old 10-15-2003, 10:24 PM
LS1TECH Sponsor
foff667's Avatar
im actually in the process of making one...with a welder it should cost less than 20 dollars in parts...right now im up to 10 and more than halfway done lol.
lata
bill
Old 10-15-2003, 10:47 PM
single digit dreamer
parish8's Avatar
that thing isn't held in by a couple of rubber bands is it? you think it will stay put with some 1.4 60' times?
Old 10-15-2003, 11:09 PM
TransAmDriver's Avatar
Thats would be my concern also, the last thing I need is my laptop flying into the back.
Old 10-16-2003, 08:15 AM
LS1TECH Sponsor
foff667's Avatar
I think on the afterthoughts design they use steel cable or something not sure but it also has nothing to hold the laptop open under extreme gforces so I'd end up making a bracket to hold it open but whos gonna have the laptop open directly in front of them so the g-forces hit it strait on? it would all be sideloaded meaning it shouldnt fold at all. I've used my laptop in my car on hundreds of occasions not that im pulling the g's some of you are but sideloading it wouldnt mess too much with it unless your lifting the front tires 4 feet in the air and coming down like a freight train which would in the end close it...a hinged bracket would be an easy fix either way but probably not necessary.
lata
Bill
Old 10-16-2003, 10:46 AM
horist's Avatar
I have the stand by afterthoughts and it's a very nice piece... very easily adjusted, easily removed for passengers...
Sturdy piece... granted I'm not cutting 1.4 second 60' times but I've taken some hard turns and hard brakes and the laptop stays where it's supposed to.
Laptop is secured by two rubber coated steel lines, plus there's friction pads under the laptop... so it really doesn't go anywhere...
Moves around alot less than my laptop used to while on the passenger seat
Old 10-16-2003, 12:43 PM
LS1TECH Sponsor
foff667's Avatar
i think instead of the friction pads i'll incorporate a couple strips of velcro still not sure how to hold it down but maybe you guys can help http://store5.yimg.com/I/afterthough..._1761_38470723 where the rod meets the mounting plate did they use some thin sheet metal and weld that to the rod and then to the plate to hold it in place? I'm trying to brainstorm to find thee strongest way to do this for anyone that wants to donate a few bucks to get one for themselves I'd like to do it right the first time and cheap. If anyone has any ideas on if my sheetmetal idea would work or if they think they have somethingi better let me know id like to try what works.
lata
Bill
Old 10-16-2003, 01:10 PM
66ImpalaLT1's Avatar
It never occured to me until I saw a friend do it. You can use the seat belt to hold the laptop on the passenger seat.
Old 10-16-2003, 01:37 PM
LS1TECH Sponsor
foff667's Avatar
i use my case and wrap that around the pass seat but its very incomfortable having to twist my body all over the place just to type in some letters.
Old 10-22-2003, 06:59 AM
I sent a picture of the laptop stand to my buddy Jeff last year. His only comment was about adding weight to his 9 second Z-28. However, I'm inclined to worry about a 1.30-1.40 60ft time causing the laptop problems on the mount.
Having a $1500 laptop become a flying projectile sounds bad. Very bad. I suppose if you really lash that baby down, and put it down low for hard launches it would be okay.
Old 06-15-2004, 04:00 PM
Ed Blown Vert's Avatar
Are you able to configure the laptop sideways so you can see it and allow for a passenger and still clear the center console?
Old 06-15-2004, 04:02 PM
slow's Avatar
lata
bill
i would love to see pics.
I was just planning on building one.. and came across this thread.
Ryan.
Old 06-15-2004, 04:24 PM
horist's Avatar
yes, it has several pivot spots... granted it's not the most comfy or safe thing if you have a passenger, but it can be moved around in many directions.
The top portion comes off really easily ... so when I have passengers in my car I just take the laptop tray off and stick it in back.. (thumb screw, takes all of 5 seconds)
I've also had passengers in the car w/the laptop stand in front of them watching as I log... however I would not reccommend this as it's positioned right where the air bags are... so 1 bad mistake and your laptop may get a lil bloody...
Old 06-15-2004, 04:55 PM
How low can you get it to the passenger-seat?
I have been thinking about getting one. Was it worth the $$$?
Old 07-15-2004, 06:17 PM
Brody's Avatar
Has anyone mounted a laptop up in a C5? Are the mounting points the same b/w F-Body and C5's?
Old 07-15-2004, 08:09 PM
BTW, I bought one. Love it!
Old 07-15-2004, 09:37 PM
Ragtop 99's Avatar
Tom:
If the passenger seat is out, you could easily rig up a stand to fit your laptop and secure it to the car using the seat studs.
Old 07-15-2004, 10:22 PM
Brody's Avatar
Looks great! Which unit is this? Is there something you're using to help hold the laptop open in that picture?
