Idles Fine But Takes no Gas
Old 02-26-2009, 03:51 PM
P_MotorHead's Avatar
Angry Idles Fine But Takes no Gas
I own a 1994, TA. I Just relaced OPi-SPark, water pump, and radiator. I cleaned the throttle with choke cleaner. the car has 100,000 miles and its automatic. When I start it, it idles fine but as soon as i give it gas it shuts off (pushing the pedal a little will make it go up to 800RPM). The RPM wont pass 1k. I tried putting gas throught the throttle but shuts off as soon as it gets gas. Any Ideas???
Old 02-26-2009, 03:53 PM
ss.slp.ls1's Avatar
Originally Posted by P_MotorHead
I own a 1994, TA. I Just relaced OPi-SPark, water pump, and radiator. I cleaned the throttle with choke cleaner. the car has 100,000 miles and its automatic. When I start it, it idles fine but as soon as i give it gas it shuts off. The RPM wont pass 1k. I tried putting gas throught the throttle but shuts off as soon as it gets. Any Ideas???
I have to say that is quite odd. What brand opti did you get? Are you positive that all of your wires are routed correctly and fully seated? I would double and triple check them, not kidding.
Old 02-26-2009, 04:03 PM
The Opi is a AC DELCO, bought it from e-bay. ill check the plugs agian.
Old 02-26-2009, 04:05 PM
ss.slp.ls1's Avatar
Oh no...who did you buy it from? Please tell me it was "thepartsladi" and not something like AllIgnition.
Yes, check the wires again.
Old 02-26-2009, 05:53 PM
Ihasfip's Avatar
I couldn't be some fluke TPS or something would it?
D
Old 02-26-2009, 06:03 PM
RamAir95TA's Avatar
I've always understood that you can not use carb cleaner on a fuel injected engine. I'd put money that you fouled something out (MAF, TPS, MAP, IAC). Easiest way to tell is to get it on a scanner and monitor what's going on when it stalls.
Old 02-26-2009, 07:01 PM
ss.slp.ls1's Avatar
As long as you spray it on and wipe it off without getting it on a sensor, there's nothing wrong with it. Most say throttle body/carb cleaner.
Old 02-26-2009, 07:02 PM
ThoR294's Avatar
i use carb cleaner to clean my TB blades... no problems.
Old 02-26-2009, 08:05 PM
JB_97ws6TA's Avatar
has it kicked out any codes??
Old 02-26-2009, 08:47 PM
RamAir95TA's Avatar
Exactly what I mean.
http://www6.worldisround.com/photos/0/318/71.jpg
Old 02-27-2009, 03:36 PM
95 TA - The Beast's Avatar
One thing to check for is to make sure the exhaust is not clogged, as in a bad catalytic converter...
It will do just as you said, idle fine, but any RPMS and it will stall out... Actually if this has been a progressional thing, did you notice teh car not making power and power starting to drop off rapidly? If so, and you have a catalytic converter on the car, there is a great chance it is borken up and clogging the exhaust...
Only way to tell is to pull the cat off and look at it... You can try banging on it to see if you can hear pieces loose in it, but that is far from a definitive test if it is silent... If you hear stuff rattling around, you can be certain is is broken.
Just something else to checkout...
Old 02-27-2009, 03:38 PM
Ok I checked if any spark plugs are put on wrong and there not, every spark plugs are in right order. also, the throttle body kicks back white smoke, it rarely happens but it happens. out of the hundred time i started the car it happen 3 times. Already checked the CAT a good amount of air come out the exhaust, I'll remove the cat completely tomorrow. the car has been sitting for about 3-6 weeks with no start. i changed the radiator cause it was spraying water everywhere, a buddy of mine said to change some sensors might be wet. any opinions?? by the way its a 93 TA with the MAF being under the trottle body not on the air intake.
Old 02-27-2009, 04:47 PM
ThoR294's Avatar
93s do not have MAFs... they have MAP sensors
Old 02-27-2009, 05:27 PM
ss.slp.ls1's Avatar
All years have MAP sensors. '93 runs in speed density, so it doesn't utilize a MAF sensor.
Old 02-27-2009, 05:29 PM
ElkySS's Avatar
try the engine coolant temp sensor in the water pump
Quick Reply: Idles Fine But Takes no Gas
