Fuel pump removal
Old 03-05-2009, 10:51 PM
alconk's Avatar
Default Fuel pump removal
I'm about to replace the fuel pump and last time it was a nightmare dropping the axel, exhaust,and tank. This time I plan on pulling it from the top and someone on here a long time ago had everything laid out with dimenshions, placement and making a cover. It looked factory. I saved the piece into my documents but the harddrive took a **** and lost it all. Does anyone know where I can get this info back??
Old 03-05-2009, 10:56 PM
7.0 camaro's Avatar
i can t help you on where to find that info. but it seems like the fuel pump hole should be cut toward the front and in the center if that big hump. i would just guess its 6x6 hole would be enough to get it out. maybe a little bigger.
Old 03-05-2009, 11:25 PM
alconk's Avatar
Well thank you but someone had it planned out to a "T". It was perfect.
Old 03-05-2009, 11:33 PM
Black93_Formula's Avatar
is this what your talking about? hope it helps
http://www.fastbird93.com/Installations/Racetronix.htm
Old 03-06-2009, 04:52 AM
RamAir95TA's Avatar
http://www6.worldisround.com/photos/1/134/3.jpg
Old 03-06-2009, 07:37 AM
moehorsepower's Avatar
I believe Shoebox or something of that name has all of the dimensions,,Very good info...
Old 03-06-2009, 07:56 AM
monster81's Avatar
this link is all u need
http://www.taekwondoplus.org/z28/fuelpump.html
Old 03-06-2009, 09:10 AM
hawk584's Avatar
i recommend pneumatic shears. measure out a rectangle, drill a pilot hole, shear the sheet metal. very easy, no sparks, safer... took my friend and i about 1.5 total with a custom cover.
something like these: http://www.bosstoolsupply.com/index....OD&ProdID=5595
Old 03-06-2009, 06:28 PM
alconk's Avatar
AWESOME!!!!!! Yep this is what I was looking for.. Thanks guys!
Old 03-06-2009, 08:40 PM
the_merv's Avatar
Here is what I did..
Most cut the rectangle, I took it a step further to make it easier.
Old 03-07-2009, 09:20 PM
integraxtc's Avatar
do you guys recommend all the bolts/screws and sealant?
I saw somebody once did hinges and weather sealant (like the rubber kind) and a latch.
Old 03-07-2009, 10:35 PM
SS Junk's Avatar
i used tin snips to cut mine and it took only minutes to do.
whatever seals will work fine.
Quick Reply: Fuel pump removal
