Which heads for a 454 lsx drag race setup?
I've been thinking it would be cheaper to build a monster stoker than go the turbo route. So that being said I want to build a 454, run a single plane intake with a 4bbl throttle body, and a solid roller cam. This is all going in a heavy GTO with a TH400 4000-5000 stall. I want to be able to rev it to 7k also.
What heads should I choose?
But if you can't wait, ported LS7's are good for N/A, if you're gonna spray it use the thicker deck heads by ET or All-Pro.
