11.0 to 1 compression on 10lbs.
Old 03-17-2009, 10:03 AM
dpinson's Avatar
Default 11.0 to 1 compression on 10lbs.
has any body tried this
i was wondering what you guys thought about running 10 lbs on 11.0to 1 compression with a forged bottom end and meth
is it possible and would it be reliable or would it be a time bomb
Old 03-17-2009, 10:43 AM
LS1Tech Sponsor
Mike@Diablosport's Avatar
LS1Tech 10 Year
Assuming the bottom end is screwed together well, and the tune is 100% spot on, you should be OK.
Old 03-17-2009, 11:06 AM
30th t/a's Avatar
I think you would be Ok. Cablebandit is running 10.3:1 with meth and he loves it.
Im bumping my CR up to 10:1, maybe even a tad more.
Old 03-17-2009, 11:07 AM
dpinson's Avatar
all arp hardware and,yeah i think it is put together well i have had a few mishaps with nitrous that would have blown a few engines apart but mine is still holding strong
any other opinions
Old 03-17-2009, 12:01 PM
BigRich954RR's Avatar
11. 1 here on 15 psi meth and pump 93
Old 03-17-2009, 12:11 PM
NemeSS's Avatar
woo hoo!
details on your setup?
Old 03-17-2009, 12:12 PM
tollway bandit 1's Avatar
My motor is at HKE for that set right now, but on 18psi.
Old 03-17-2009, 01:07 PM
dpinson's Avatar
ILL ONLY BE PUTTING ABOUT 10LBS UNTIL I SEND THE P1SC IN TO SWAP FOR A D1
and was just trying to get the most out of what i have now
if you guys think it is ok i will probably leave my heads on there for now and go see what she does on 10 lbs
im hoping i can at least cross the 550rwhp for now
ill be happy with that for now untill i can throw some more boost at it
Old 03-17-2009, 01:59 PM
NVigR8's Avatar
I'm running 9psi from my magnacharger MP122 on a 10.9:1 compression forged stroker. No issues, I'm even going to bump up the boost a little. The pulley is on order.
Old 03-17-2009, 07:48 PM
XpEdItIoUs's Avatar
Damn how much power are you making?
Old 03-18-2009, 12:38 AM
Rickys S/C Z28's Avatar
you will be fine im running 9:8:1 with no meth and love it
Old 03-18-2009, 01:33 AM
758 rwhp about that cause it keeps changing with dyno and air temps but about there.
gets around 26 mpg interstate highway in a heavy GTO
AT max boost im flowing 300 lbs of meth its a dual 15gph and 10gph at 100psi nozzle meth kit. think i could lower the meth but im not willing to chance it. sucking in alot of hot air with my air intake. close to headers.
10k mile running like this so far, going strong
Sorry guys would answer more but just left bar and chick ready now
