converter question
LS1Tech Sponsor
Don't make a decision without talking to FTI
Check out our link below for more information on our FTI Converters and give us a call for more information on what would best for your exact application.
https://ls1tech.com/forums/automatic...onverters.html
Thanks,
Greg
Thanks,
Greg
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
1-866-726-8358
FTIPerformance.com
tci has been around along time, i wouldnt consider it to be cheap made.
yeah i know the vig is probably going to be faster but is it $ 300 worth faster if the car runs 11:80s.
You are comparing 2 totaly different styles of converters. The TCI lacks the billet front and uses a much smaller 9.5" lock up clutch. The Yank will have a billet front cover and much larger clutch. So even if the performance was the same, durability is very different. If the lock up clutch goes out, it can and probably will take out your transmission, costing a lot more than the $300 you supposedly saved.
FYI, I thought I would throw in a shameless plug for our Circle D Billet series, We will move you
If you are on a budget, we offer an 11" 3200 stall for the LS1's. They do not have the billet front but do use a OE 12" front cover and clutch - so they are still very strong.
Chris
Chris
This is why WITH PICS!!!!!! --->>> https://ls1tech.com/forums/automatic...education.html
This one in peticular, TCI on the left, PI on the right.
https://ls1tech.com/forums/automatic...-breaking.html
https://ls1tech.com/forums/automatic...p-problem.html
Thats just a few............ You get get what you pay for
LS1Tech Sponsor
If we're showing pics this is what a FTI SRLS series looks like. No dampner to break, monster clutch, billet piston, billet cover, furnace brazed & tig welded, chromemoly hub, etc...
ENJOY!
Thanks,
Greg
ENJOY!
Thanks,
Greg
__________________
1-866-726-8358
FTIPerformance.com
1-866-726-8358
FTIPerformance.com
What the heck, I will show off some pics too. Here is our Multi Disk. 3 Times more lock up surface area than a billet single disk.
The multi disk is a very tough converter. It is recommended for FI setup or big nitrous cars. The typical NA car will not show any benefit from a WOT lock up, so the billet single disk is good.
Chris
Chris
LS1Tech Sponsor
Come on Dave (Yank) where's your pics. At a boy Chris. Now lets compare apples to apples. I can put pics of my bolt together on here if you would like!!!!
Greg
Greg
__________________
1-866-726-8358
FTIPerformance.com
1-866-726-8358
FTIPerformance.com
